Home > Puma (Tdci) > Chudering when I lift off? |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 |
Check your oils in the diffs and transfer box.
Clunk as you lift off and on the throttle could be backlash in the diff but also worth checking the prop shaft ujs Hold my beer and watch this! |
18th Dec 2019 3:32pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
springs gone in the clutch? possibly the small springs in the centre bit and not necessarily the main springs?
18th Dec 2019 3:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
It can also be worn half-shafts and or flanges too. $W33T $0U7H3RN $UG4R
18th Dec 2019 4:41pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
chuddering is usually handbrake binding
if its a whine, everything in the driveline is worth checking UJs drive members shafts diff if its a whine noise and transmission related most likley to be a diff in my experience when in coast. The resistance to driving is the speed the same as it was for any given gear/rpm? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
18th Dec 2019 6:39pm |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
I think my handbrake might be binding. When I start moving and pressing petrol there is a shudder I feel and hear in the drive train. The traction controll light also comes on then. Or.... Is it perhaps an issue with the traction controll sensors? |
18th Dec 2019 6:48pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Handbrake is easy to check; just wind the adjuster in until it bites then back it if 1.5 turns. This is how it should be set, with any slack taken up by the handbrake cable adjuster instead. When I had the issue I wound mine in quarter turn and it bit, so I knew it wasn’t right! Chuddering gone after this!
18th Dec 2019 8:04pm |
Is this adjuster located on the housing of the handbrake? |
19th Dec 2019 6:46am |
Yes. Square adjuster on the fixed side of the drum.
19th Dec 2019 12:54pm |
I pulled the 2 fuses for tc and abs and the problem is gone. Next step is to clean those speed sensors on the wheels i guess.
19th Dec 2019 2:24pm |
