Home > Puma (Tdci) > Chudering when I lift off?
Stacey007
Hello
I'm guessing my diffs need some maintennace, but while driving along at almost any speed but more so over say 40mph if you lift off completelty the acceslerator the truck does have quiote a wine now (and no the mother in law is not in the car)
Also driving along at say 40mph the truck almost feels like it not getting enough fuel, hard to exsplain but like a stutter. Cannot describe it but not getting enough fuel is how I would say almost juering a little.
other than this is driving very well, keeps getting 30mpg or more and is almost on 100K miles now. Thumbs Up
The above noioses, any idea what it is thats wearing out....?
Post #806762 18th Dec 2019 3:17pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Check your oils in the diffs and transfer box.
Clunk as you lift off and on the throttle could be backlash in the diff but also worth checking the prop shaft ujs Hold my beer and watch this!
Post #806764 18th Dec 2019 3:32pm
Caterham
springs gone in the clutch? possibly the small springs in the centre bit and not necessarily the main springs?
Post #806769 18th Dec 2019 3:57pm
It can also be worn half-shafts and or flanges too. Chillin In The Backwoods🇬🇧🇺🇸
Post #806776 18th Dec 2019 4:41pm
jst
chuddering is usually handbrake binding
if its a whine, everything in the driveline is worth checking
UJs
drive members
shafts
diff
if its a whine noise and transmission related most likley to be a diff in my experience when in coast.
The resistance to driving is the speed the same as it was for any given gear/rpm? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #806796 18th Dec 2019 6:39pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I think my handbrake might be binding. When I start moving and pressing petrol there is a shudder I feel and hear in the drive train. The traction controll light also comes on then.
Or.... Is it perhaps an issue with the traction controll sensors?
Post #806798 18th Dec 2019 6:48pm
Co1
Handbrake is easy to check; just wind the adjuster in until it bites then back it if 1.5 turns. This is how it should be set, with any slack taken up by the handbrake cable adjuster instead. When I had the issue I wound mine in quarter turn and it bit, so I knew it wasn’t right! Chuddering gone after this!
Post #806810 18th Dec 2019 8:04pm
Marius
Is this adjuster located on the housing of the handbrake?
Post #806836 19th Dec 2019 6:46am
Co1
Yes. Square adjuster on the fixed side of the drum.
Post #806869 19th Dec 2019 12:54pm
Marius
I pulled the 2 fuses for tc and abs and the problem is gone. Next step is to clean those speed sensors on the wheels i guess.
Post #806884 19th Dec 2019 2:24pm
