Home > Puma (Tdci) > Yet another issue.......
Page 1 of 3 123>
Markez79
This time the engine cuts out when I'm driving......not great when I'm on a roundabout as happened at the weekend Shocked Wife wasn't very amused.....said something rude about the reliability of my pride and joy!
I have had the EGR 'blocked' at the same time I got the BAS remap done at the start of the year and she has just had a service so I'm assuming that something major would have been picked up when running diagnostics?
The symptoms:
Driving along.....revs drop.....I can rev the engine but just coasting with no 'drive'....and then just dies.
Any thoughts??
Thanks
Mark
Post #806438 16th Dec 2019 11:07am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
is it warm or cold ? maf sensor worth a look give it a clean if since service it may be something to do with that
Post #806445 16th Dec 2019 11:54am
Volume control valve.
Post #806463 16th Dec 2019 1:46pm
Markez79
Happens when car is cold and warm..... Rolling Eyes
Post #806469 16th Dec 2019 3:40pm
williamthedog
As Blackwolf has already said, vcv valve seems the likely suspect.
Post #806473 16th Dec 2019 3:51pm
Markez79
Many thanks as ever guys.
Expensive to replace?
Mark
Post #806571 17th Dec 2019 8:57am
dorsetsmith
have look below
https://bellautoservices.co.uk/bas2rrc-hel...4tdci/vcv/
part no LR009837
https://bellautoservices.co.uk/store/defen...our-valve/
Post #806572 17th Dec 2019 9:03am
Markez79
Many thanks
Post #806600 17th Dec 2019 11:29am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Mark
You can get Denso branded for about £60 and unbranded for about £30
You can change yourself - only issue is awkward to access the bolts - there is full thread on here with pics on how to do it and the tool - ratchet wrench with extensions/universal joint
Post #806607 17th Dec 2019 12:29pm
Def Junkie
Re: Yet another issue.......
The symptoms:
Any thoughts??
Thanks
Mark
Hi Mark, was wondering if you've managed to fix the issue described here? I am struggling with the exact same issue.
Tim
Post #807635 26th Dec 2019 12:10pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
You need to have this response as an autoreply really. Whistle
Post #807636 26th Dec 2019 12:17pm
I do!
Post #807689 26th Dec 2019 6:30pm
That’s usually because most of the time Blackwolf is right. Very Happy Chillin In The Backwoods🇬🇧🇺🇸
Post #807690 26th Dec 2019 6:48pm
Def Junkie
So I've had the VCV replaced (Denzo) but the problem persists. Big Cry
It suddenly loses power (when accelerating hard), does not respond to the accelerator, coasts along and then dies.
Any help much appreciated Bow down
Post #809306 8th Jan 2020 6:24am
Naks
Hmmm, could be a dirty fuel pickup in the tank?
Time to drop the tank and inspect it - there could be crud around the fuel pickup, and when you put foot, the increased fuel flow is compromised by the blockage. --
Post #809309 8th Jan 2020 7:22am
Page 1 of 3 123>
