Home > Maintenance & Modifications > Recommendations for Anti-Seize products
Peregrine_White
United Kingdom 2008 Defender 90 Puma 2.4 SW Keswick Green
I traditionally have used copper slip on stainless steel bolts when putting them into the aluminium on my defender to minimise the dissimilar metal effects. However before i go and buy a new tub I was reading that normal grease is better. Any input would be greatly appreciated!
Post #804733 4th Dec 2019 3:58pm
landy andy
If you want the good stuff, this is it.
https://www.rocol.com/products/stainless-steel-anti-seize
But I just use copper slip, as it has many other uses and is cheap.
Post #804734 4th Dec 2019 4:08pm
Zed
I use this stuff. https://www.amazon.co.uk/Weicon-26100045-H...rds=weicon WARNING.
Post #804736 4th Dec 2019 4:15pm
I use Weicon paste whenever I have the misfortune to need to use stainless fasteners. It's very good stuff.
Post #804744 4th Dec 2019 4:59pm
Peregrine_White
Perfect ordered a tub, thanks everyone!
Post #804746 4th Dec 2019 5:12pm
Bluest
I use ceramic brake grease, current tub in made by Granville. Not Arkwright's helper I don't think. 2007 110 TDCi Station Wagon XS
Post #804748 4th Dec 2019 5:36pm
ericvv
Post #804763 4th Dec 2019 7:25pm
Fatbaron
I've always used copper slip but am going to start using the Molly grease I've just bought from Gwyn Lewis and see how that goes.
Post #804766 4th Dec 2019 8:22pm
Thon
ericvv wrote:
Interesting, some on here have seen the light. Whistle Weicon Thumbs Up
Ceramic grease then again is the best product for wheel hubs.
Eric
I use (have always used for the last 30+ years) copper grease for hubs / wheel nuts / wheel spindles - it has never failed to prevent them seizing.
What makes ceramic better?
Post #804779 4th Dec 2019 9:37pm
Which type was it that came with the Naka SS bolt kits?
I have half a tube of that still and it’s lasted me literally years for my needs. TheThunder Rolls🇬🇧🇺🇸
Post #804783 4th Dec 2019 9:58pm
Zed
Berner.
They also sell tubs branded BMP. This also comes in small packets with other Nakatanenga fittings.
I'm no expert but they all seem much of a muchness to me. However the Weicon was more readily available. WARNING.
Post #804785 4th Dec 2019 10:08pm
ericvv
Post #804787 4th Dec 2019 10:18pm
ericvv wrote:
Ceramic is totally metals free. So ideal for isolating a steel hub from an alloy wheel.
Eric
But so is the Weicon?
Don't remember what it says for Copaslip but the Weicon states: "Original sealed containers have a shelf life of 24 months."
So, once opened it's good for how long? At the rate most DIYers go through a product like this, that must be most of the product either going in the bin or being used well outside it's design life. Confused
Post #804808 5th Dec 2019 7:31am
Re: Recommendations for Anti-Seize products
Hylomar blue might be your friend for this application.
The original product was developed in conjunction with Rolls-Royce and was used for sealing aircraft engines.
Post #804810 5th Dec 2019 7:44am
