Home > Maintenance & Modifications > Recommendations for Anti-Seize products |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
If you want the good stuff, this is it.
https://www.rocol.com/products/stainless-steel-anti-seize But I just use copper slip, as it has many other uses and is cheap. |
4th Dec 2019 4:08pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3292 |
I use this stuff. https://www.amazon.co.uk/Weicon-26100045-H...rds=weicon WARNING.
This post may contain sarcasm. |
4th Dec 2019 4:15pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
I use Weicon paste whenever I have the misfortune to need to use stainless fasteners. It's very good stuff.
4th Dec 2019 4:59pm |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 |
Perfect ordered a tub, thanks everyone!
4th Dec 2019 5:12pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
I use ceramic brake grease, current tub in made by Granville. Not Arkwright's helper I don't think. 2007 110 TDCi Station Wagon XS
4th Dec 2019 5:36pm |
Interesting, some on here have seen the light. Weicon
Ceramic grease then again is the best product for wheel hubs. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4th Dec 2019 7:25pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
I've always used copper slip but am going to start using the Molly grease I've just bought from Gwyn Lewis and see how that goes.
4th Dec 2019 8:22pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I use (have always used for the last 30+ years) copper grease for hubs / wheel nuts / wheel spindles - it has never failed to prevent them seizing. What makes ceramic better? |
4th Dec 2019 9:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20378 |
Which type was it that came with the Naka SS bolt kits?
I have half a tube of that still and itโs lasted me literally years for my needs. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
4th Dec 2019 9:58pm |
Berner.
They also sell tubs branded BMP. This also comes in small packets with other Nakatanenga fittings. I'm no expert but they all seem much of a muchness to me. However the Weicon was more readily available. WARNING. This post may contain sarcasm. |
4th Dec 2019 10:08pm |
Ceramic is totally metals free. So ideal for isolating a steel hub from an alloy wheel. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4th Dec 2019 10:18pm |
But so is the Weicon? Don't remember what it says for Copaslip but the Weicon states: "Original sealed containers have a shelf life of 24 months." So, once opened it's good for how long? At the rate most DIYers go through a product like this, that must be most of the product either going in the bin or being used well outside it's design life. Last edited by Supacat on 5th Dec 2019 7:46am. Edited 1 time in total |
5th Dec 2019 7:31am |
Hylomar blue might be your friend for this application. The original product was developed in conjunction with Rolls-Royce and was used for sealing aircraft engines. |
5th Dec 2019 7:44am |
