![]() | Home > Td5 > Td5 defender ABS pump gone |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Aren't the ones off D2 the same? I'm sure I read that somewhere
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
Hi, no I don’t think they are. 2005 TD5 90 CSW XS
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 961 ![]() ![]() ![]() |
A D2 will fit. What are your symptoms? Often you just need to rebuild the modulator shuttle valve.
https://www.amazon.ca/ABS-Modulator-Shuttl...B00YZ0C1CQ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I had it diagnosed at an independent garage they came to the conclusion that the pump has failed, £2200, for a new pump, plus 5 hours labour because it’s a Sod of a job. 2005 TD5 90 CSW XS
Anyone else😜 2005 TD5 90 CSW XS
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 ![]() ![]() ![]() |
Maybe worth considering? https://www.ecutesting.com/product-catalog...avb154000/
☝🏻 Nice! 2010 Range Rover MkIII Autobiography Super Charged (Idris)
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1640 ![]() ![]() |
get it removed
send away for repair fingers crossed it can be fixed with a new modulator etc refit, still keeping fingers crossed. d2 one is different but can be made to fit lots of info on the web about how to and yes its a pain to get off. |
Access is not unlike lambing a difficult ewe but with spanners! A mixture of working through the air intake vent and from inside the engine bay but underneath the wing top. Then try getting it all back in when you've slightly moved the brake lines when you levered them out of the way to get the unit out. You get halfway through the surgery and come to the conclusion that it may have been a better idea to take the whole wing off
Ahhh yes LHD is soooo much easier to work on 🙄 Like way easier. 🤔 2010 Range Rover MkIII Autobiography Super Charged (Idris)
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
What's the actual fault - what's gone wrong?
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
same problem here £45 modulator I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Pump failed, three amigos up on the dash? 2005 TD5 90 CSW XS |
I had this issue, got one from a breaker, £250, fitted it myself, scraped knuckles and slightly scraped paint.. easy job, made difficult with lack of space.
Worked out great ! |
