Page 1213 of 1383 <123 ... 121212131214 ... 138113821383>
excossack
Thanks JWL. If you want you can PM the pics over or attach here.
I have made a mounting plate out of stainless to mount underneath the car. Between your heater and the floor on the inside, do you just have the rubber gasket or do you have another type of gasket/plate? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #785624 7th Aug 2019 9:37pm
JWL
Just the rubber gasket on top of the seatbox if I remember correctly, mine was all secondhand and I didn't exactly go to town on it, just made it fit Wink
Post #785803 8th Aug 2019 10:17pm
excossack
That's what I have done as well. Just need to do something with the carpet under the seats now. Cut the carpet to fit, remove altogether, or find another bit of grey carpet to go in its place. 1999 Defender TD5 110
Regards
John M0VAZ
Post #785820 9th Aug 2019 8:06am
Sulisuli
Fitted shortened custom made powder coated stainless steel mudflaps to the uproar 4x4 mudflap brackets.
 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785899 9th Aug 2019 3:19pm
Sulisuli
double post Shocked 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785900 9th Aug 2019 3:20pm
Zed
Those look very smart. Nice one.
I do like Uproar. Nice people to deal with and decent stuff.
Post #785909 9th Aug 2019 3:48pm
Sulisuli
Thanks Zed and my local fab shop made the mudflaps using the rubber ones as a template but we made the radius around the exhaust slightly bigger Thumbs Up
They are 4mm think stainless steel powder coated.
Without mudflaps the backend does look odd so I’m pleased to get these fitted. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785913 9th Aug 2019 3:55pm
Zed
That’s clever. Bet you can get them super shiny too!
Post #785915 9th Aug 2019 4:00pm
Gave it a much needed wash and polish:
 Darren
Post #786380 11th Aug 2019 8:31pm
Rashers
Looks good LRA Thumbs Up
Post #786384 11th Aug 2019 8:39pm
Looks great, lots of work put in! Thumbs Up
Tonight I helped rescue a lady that had a flat battery on her C3.
How silly is it that Citroen decided to fit a cover over the battery, only positive accessible no negative terminal easily accessible nor any suitable chassis earth point all plastic. Rolling Eyes
In the end had to take the acoustic Matt off the top of the engine and then use the lifting eye, luckily free of paint.
After that no problem at all, started first time.
Enough to get home at least, it could be the battery going under, poor alternator charging current or loose connection although nothing seemed loose.
Battery not holding its charge is my guess or parasitic draw.
Mr. Green Chillin In The Backwoods🇬🇧🇺🇸
Post #786393 11th Aug 2019 9:01pm
excossack
Where did you mount your fuel pump? I was thinking underneath in waterproof box.
Just ordered some more ducting / exhaust and inlet pipe 1999 Defender TD5 110
Regards
John M0VAZ
Post #786456 12th Aug 2019 1:05pm
JWL
My fuel tank aka header tank for a Ford Orion, is just in front of the heater box under the bonnet with the pulse pump just by the side of it. The fuel delivery pipe then runs along the chassis to the heater.
Post #786532 13th Aug 2019 12:00am
excossack
Cheers JWL I have gone separate fuel tank as well but on the drivers side away from turbo/exhaust. Fuel pump was going to be mounted under the rear floor in a plastic box. 1999 Defender TD5 110
Regards
John M0VAZ
Post #786550 13th Aug 2019 7:28am
L110CDL
Spot on LRA, very nice Cool Clayton.
Keeper.
Post #786662 13th Aug 2019 7:19pm
