carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Striped out the rear axle due to a broken spring .. noticed one disc was knackered and a seized caliper .. decided to do the bushes while I'm here .. many parts on order!
![]() Should keep me busy for a while ![]() ![]() Click image to enlarge 2008 Defender 110 XS SW - M57N2 / 6HP28X |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Fantastic the finish is really good and clean. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20619 ![]() ![]() |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
How did you get under it? I need to do mine this summer, but that's what's stopping me ATM........I don't know anyone with a pit or a hydraulic ramp, so it's me crawling about in the dirt (which I don't fancy). Are normal (heavy duty - 2.5 tonne/pair) ramps OK? |
Why worry about being on the ground, getting covered in Dinitrol is worse. Trust me I've been there.
I might never be able to get up again.
Unless you go to a place that specifically does applications for you I doubt anyone would allow it due to the overspray mess that’s left behind.
Myself personally I’d never get under it unless it is on the ground, in gear handbrake on and wheel chocked and safe. I wouldn’t trust ramps or stands, and I see little point in any gained access by removing the wheel anyway. You can still mask off the brakes etc from the inside. That being said everyone has their own way of doing things, just be safe as that’s more important than metal protection at the end of the day. ![]() ⛽️🛢️⚙️🧰💪 |
Yes, they'll be fine - the whole vehicle weighs less than 2.5 tonnes. Put them under one side at a time (one front wheel and one back) to hugely increase the available access. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
604 mile round trip Loch Lomond for a spot of camping. 1999 Defender TD5 110
Went up in the misty hills to use some fuel and hours.
![]() Click image to enlarge ![]() Click image to enlarge |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
![]() Click image to enlarge Hit the Strata Florida ![]() |
![]() Click image to enlarge And some Elan Valley local lanes... |
![]() Click image to enlarge ![]() Good timez. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Looks like you had a fun time Ronin
![]() 2008 SVX 90 2000 XS TD5 90 |
