Home > Maintenance & Modifications > Fox 2.0 resevoir shocks
Page 1 of 9 123456789>
Likeomg
Seems a bit daft but its something i've like the idea of for a long time,
I currently have bilstein b6 on my defender with -1" springs from alive the 'sport' springs,
Would the 0-1" shocks work with it being lowered?
Im thinking getting the remote res, non adjustable im currently stateside and these are my options for a defender, i have plenty of luggage capacity for bringing them back...
Also will need an 'aftermarket shock tower' wonder for the size of the damper or length
Post #781517 15th Jul 2019 6:26am
hank
Can't answer your question directly, but something to consider - the fox range are available in the UK and no more expensive
For example 985-24-122 & 985-24-123 is showing as $270 = £215, but available domestically for £200. > 110 XS Double Cab
Post #781519 15th Jul 2019 7:20am
Likeomg
Interesting about the price differences, I got a reply from 4x4 fabrications staying he has them available so might just go with him...
The prices from the fox website are a bit high, they can be had for $220 each instead of 275 but maybe it’s not worth the hassle... let’s see what 4x4 fab comes back with
Post #781521 15th Jul 2019 7:33am
Likeomg
Found this kit online,
also like the look at the bilstein b8 8125 but they are about $550 a corner... Sad
Im guessing its just the external reservoir that would require the different shock tower? if i mounted this somewhere else im sure standard would work?
Post #781530 15th Jul 2019 8:18am
hank
Is there a specific reason you want the remote reservoirs? They're sexy don't me wrong! I have the standard type Fox dampers all round which I am very happy with - around £100 per corner.
You need an aftermarket shock tower as the remote hose will foul the standard dome towers. Perhaps you could change the hose fitting at the damper connection for a 90degree one I don't know but changing the shock towers would be easier.
I changed the towers anyway as you can't see the fox stickers otherwise Razz
 > 110 XS Double Cab
Post #781539 15th Jul 2019 9:50am
Likeomg
I just want Laughing
Ill see about the shock towers, need some standard height then... will start looking.
My old suspension has been on maybe 3/4 years now and maybe its time for a freshen up...
Still handles like its on rails.
I know its complete overkill but so are 362mm brakes... still have them Rolling Eyes
Post #781541 15th Jul 2019 10:06am
hank
Fair. In your first post the photo shows the reservoir being fixed to the shock tube. I'm not sure whether there is the clearance to fit like this on a Defender. You may possibly need to remotely mount them Thumbs Up
Good luck! > 110 XS Double Cab
Post #781542 15th Jul 2019 10:17am
Likeomg
Hi, thats a little billet adapter that comes with them, but yeah ill relocate the reservoir
Take it this is what you are using?
https://gwynlewis4x4.co.uk/product/std-height-hd-front-turrets/
Post #781552 15th Jul 2019 11:22am
hank
Indeed, there are various others available. These look nicely made https://www.ebay.co.uk/itm/182475370765
No complaints on the gwyn lewis ones though > 110 XS Double Cab
Post #781554 15th Jul 2019 11:48am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I spoke to Prolinx about this and they said for a lowered defender they would advise fitting if an internal spacer to limit travel to suit a lowered setup.
I also have the Gwyn Lewis turrets and have no complaints - very well made.
Post #781555 15th Jul 2019 12:08pm
hank
Just a thought, if you can't get lowered dampers then you could look at lowered turrets/rear shock mounts. I've seen them for 2", not sure about 1" > 110 XS Double Cab
Post #781560 15th Jul 2019 12:48pm
Likeomg
To be honest, my current dampers (bilstein b6) are okay for standard height and -1”
I guess if anything the damper is gonna just sit slightly more into its stroke...
Bit like mountain biking measuring sag Question
Post #781579 15th Jul 2019 3:04pm
Welshsurferdude
Wales
for a road going defender i wouldn't bother with remote reservoir ones
ones like simon has are more than enough Smile
I had a full set on my last 110 and they were ace, currently running Bilstein b6 atm 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #781581 15th Jul 2019 3:25pm
Likeomg
It’s more of a show car / tow car / throw the bikes on roof
Heart is set on remote reservoirs... I really did contemplate the adjustable rears for when towing the boat about 2.6 ton unloaded...
Post #781582 15th Jul 2019 3:36pm
Sulisuli
Have you got these fitted yet? I’m about to fix Fox dampers without the external res and I also tow a heavy boat approx 2.5 ton will be interesting to see how they handle Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783268 26th Jul 2019 6:13pm
