Home > Puma (Tdci) > Air box modification - Do it!!
Page 2 of 6 <123456>
I have sealed but standard piping on mine. But it is indeed worth doing.
The Puma is quite thirsty with its air consumption, it’s surprising how much restriction there is in there. WeWillWin🇬🇧🇺🇸
Post #778530 22nd Jun 2019 6:26pm
Morepower
New Zealand
Bowler did a lovely airbox kit... but it was serious moo-la It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #778823 24th Jun 2019 7:23pm
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
Just managed to disappear out to the garage this evening and removed the impeller thing a ma jig!! 👍🏼
Wont be driving it till the weekend but anything to make it breathe a little better, excited to see if the “lack of feel” bottom end improves
Post #778828 24th Jun 2019 8:47pm
Guy
Sounds like a great mod to improve drivability slightly!
DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped.
**FOR SALE**
SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD.
GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD.
PINGU - '96 Defender 110 300Tdi station wagon. SOLD.
Dream LR - 130 pop top station wagon camper.
Post #778851 24th Jun 2019 10:02pm
Sulisuli
Just done this mod today, every little helps Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #778852 24th Jun 2019 10:11pm
Do remember that the centrifugal separator is there for a purpose and if you remove it and do nothing else you are more likely to end up with a saturated paper air filter element in very wet or humid conditions. Unless you fit a more sophisticated prefilter as part of a more thorough upgrade, you might want to check the condition of your air filter element more often.
Post #778892 25th Jun 2019 7:41am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Thank you Blackwolf, I’ll certainly remember to do that .
To be honest I didn’t try the new pipe work with the impeller still attached , I probably should have as the larger diameter pipe is what would logically make the biggest difference . Luckily I didn’t have to butcher the pipe work to remove anything so I may try it with it back in . https://www.instagram.com/hustynminepark/
Post #778932 25th Jun 2019 12:32pm
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Is there a step-by-step guide for this mod available?
Post #778937 25th Jun 2019 1:08pm
Does anyone actually know the OEM of the Genuine air filters? WeWillWin🇬🇧🇺🇸
Post #778955 25th Jun 2019 3:57pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Blimey, old thread...…. Remember doing this mod with Porny back in the day. Putting Dreams on Drives at JLR Solihull..
Post #779013 25th Jun 2019 9:51pm
Sulisuli
Old thread but new owners which is what makes this forum so good, so much knowledge to share. Thumbs Up
‘Have you had any problems since you did yours adafish? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779015 25th Jun 2019 9:56pm
adafish
NO, I meant I was working with Porny on the idea down at IRB at the time. Did a fair few early Puma back then, even his own development 90...Goode old days of R&D , many late nights and rolling road days... Putting Dreams on Drives at JLR Solihull..
Post #779079 26th Jun 2019 11:21am
Roy5695
No problems with my airfilter in 4 years Simon, not with the standard pipe, snorkel, silicone replacement pipe
Or my new 4” pipe setup. Not even a hint of a damp filter. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #779114 26th Jun 2019 4:36pm
No problems here either. WeWillWin🇬🇧🇺🇸
Post #779116 26th Jun 2019 4:38pm
diduan
Bulgaria
I removed the propeller-like-thing today. I didn't cut anything, just unhooked it with a screwdriver and took it away. Initially the plan was to remove the complete air box, but after I had it loose I realised that it wont come up because of the air-conditioning. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #820239 19th Mar 2020 4:23pm
