Home > Puma (Tdci) > Air box modification - Do it!!
Page 3 of 6 <123456>
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Is that all that is involved with the modification? Removing the propeller?
Post #820240 19th Mar 2020 3:42pm
diduan
Bulgaria
I don't know, I did it because due to the current situation I have lots of free time. I personally do not belive the propeller is making the inlet air any drier, but on the other hand it seems to be significant restriction of the air flow. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #820242 19th Mar 2020 4:09pm
I'm curious as to whether a more unrestricted air flow will actually benefit anything?
I understand the logic on an "analogue" engine but ours are now fully "digital".
There's a number of air flow sensors and the standard ecu must have other set parameters including wheel speed and the like, so I just wonder if it just hits another limit, either physical or software related within the overall system?
Post #820253 19th Mar 2020 5:18pm
Improving the induction system makes a massive difference to the performance and smooth running of the engine.
Post #820260 19th Mar 2020 6:29pm
Co1
When I took the diffuser out of mine there was an instant noticeable difference to how smooth the engine ran. It revved more freely and sounded much sweeter at idle.
Post #820261 19th Mar 2020 6:35pm
I agree with the statement Blackwolf mentioned - This is what happened with mine in a real world scenario.
Removing the rain separator isn't the only thing it's the inlet to cut out in the base of the air box.
You do have to be careful if you do, I used a hot knife if I remember rightly.
I used to have a picture of inside the air box but I don't have it any more.
Basically as you look in the air box you'll see at the bottom the large inlet hole.
You need to remove this round plastic piece inside the air box which then leads out of the air box to the left.
Leaving the outer structure of the air box body only.
This allows the air to come in from the left and up with less restriction rather than being in that restrictive piece in the bottom of the air box.
It is definitely worth doing. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #820270 19th Mar 2020 8:31pm
Way to go, HUGE difference!
Post #820272 19th Mar 2020 8:39pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Seconded. Nuggetstuff kit makes a big difference. WARNING.
This post may contain sarcasm.
Post #820273 19th Mar 2020 8:44pm
diduan
Bulgaria
I drove it today to the near town and back. I don't see a wow effect, but the engine performs better in low rpms. I think the "1st-2nd gear struggle" is somehow cured now and for me this is a big Thumbs Up Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #820521 21st Mar 2020 4:03pm
Merlin
Definitely better.
Post #820543 21st Mar 2020 6:53pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Did mine yesterday and added the Nugget RAI adapter kit now I have some time on my hands. Mine already has a remap but it seems to pull a lot smoother below 2000 revs and just feels better somehow. Well worth it.
Post #821852 28th Mar 2020 6:33pm
Planetary
New Zealand 2013 Defender 110 Puma 2.2 SW Loire Blue
I did the airbox mod today and was very pleasantly surprised at the result. It is actually now very pleasant to drive, All the horrible shunting/bunny hopping has gone, and the light throttle 1-2000rpm is useable for slow speed driving.
I do understand the downside of removing the water seperator, but with a Mantec RAI and a Nugget sealed air duct on the way I think I have water ingress covered.
And yes, I do consider the snorkel to be an essential piece of kit (one of our best local trails has 26 river crossings!). I'ts not there to turn it into a submarine, but that one day when you are crossing that river at a sensible depth and the wheel drops into a hole you didn't see, then it will save you.
Post #841429 3rd Jul 2020 6:55am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Great mod and An instant difference , I fitted the Nugget Air Filter housing last week and again there’s a noticeable change in performance , with throttle response and turbo . The engine sound is noticeably different as well .
It was a lot of money and I had my doubts but am really pleased .
If you do both in one go , the difference would be hugely noticeable https://www.instagram.com/hustynminepark/
Post #841438 3rd Jul 2020 7:46am
chrisrigbywork@gmail.com
England 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi guys,
Ive currently got a hybrid turbo and a remap with a raised air intake snorkel with a nuggetstuff sealed air box system. At the moment currently my air box cant handle the air intake keeps coming up with change air filter as soon as i put some power down. Any ideas do i need to get rid of the nugget stuff air filter box and go back to standard any ideas would be appreciated it thanks
Post #970939 13th Nov 2022 3:55am
Naks
how on earth have I not seen this mod before???
damn you, now I have to get one Rolling Eyes --
Post #970940 13th Nov 2022 5:05am
