Home > Puma (Tdci) > Air box modification - Do it!!
Page 5 of 6 <123456>
nitram17
As you say its a gimmick i would ignore it also ..but it must be a known problem with snorkel pre filters fitted as i doubt nugget would host a video clearly stating the issue...trust you to go for the biggest bore available Wink
Post #971595 18th Nov 2022 4:05pm
That's me! Rolling with laughter
Post #971599 18th Nov 2022 4:18pm
swt wrote:
The filters are a standard size. A Mahle equivalent is on the Opie Oils website for £15 at present. It's the filter from a Ford Maverick.
Part numbers I noted for the NuggetStuff filter when I was looking for sensibly-priced alternatives:
  • 16546-04N00
  • Wesfil WA830 or A1203
  • Mahle LX830
Googling any of these numbers will find further alternatives, it is a widely used filter.
Post #971673 19th Nov 2022 10:21am
Ianh
Blackwolf “its a widely used filter” , your not kidding Smile, these are the ones quoted by Parts in motion, a parts supplier I tend to use for true OEM EGRs etc.
Interesting to note is the height of the filter for different manufacturers ranges from 175-178mm and the hole in the bottom, that if I recall correctly, sits on the conical rubber mount in the airbox, ranges from circa 8-10mm, I expect both measurements combine to insure a tight fit
1A FIRST AUTOMOTIVE A60579
ALCO FILTER MD652
AMC Filter IA-385
ASHIKA 20-01-110
BOSCH 1 457 433 275
BREMSI FA2230
CHAMPION W708/606
CLEAN FILTERS MA620
Comline CNS12008, CNS12226
CONTINENTAL 28.0002-0278.2
Coopersfiaam FLI6819
DENCKERMANN A140202
DIAMAX DA2222
DJ PARTS FA1545
Dr!ve+ DP1110.10.0277
DYNAMATRIX DAF830
FIL FILTER HP 4554 A
Filtron AM436/1
FLEETGUARD AF1822
Fram CA5369
GCG TURBOS AUSTRALIA RY-A1203
GOODWILL AG 477
HERTH+BUSS JAKOPARTS J1321017
HOFFER 16330, 16449
IAP QUALITY PARTS 121-13042
JAPANPARTS FA-110S
JAPKO 20110
JC PREMIUM B21017PR
JPN 20F1013-JPN
JS ASAKASHI A226J
KAGER 12-0220
KAISHIN A226
KAVO PARTS IA--385, IA-385
KLAXCAR FRANCE FA260z
KNECHT LX 830
LUCAS FILTERS LFAF359
LYNXauto LA-269
MAGNETI MARELLI 152071758561, eBay Item No. 154084455530
MAHLE LX 830
MANDO MMF015095
MANN-FILTER C 13 103/1
MAPCO 60542
MASTER-SPORT GERMANY 13103/1-LF-PCS-MS
MASUMA MFA-349
MAXGEAR 26-1591
Mchanix NSARF-004
MDR MAF-3110
MEAT & DORIA 16330, 16449
MECAFILTER EL3808
MFILTER A 143
MISFAT RM973
MOTAQUIP VFA669
MULLER FILTER PA579
NIPPARTS J1321017
NPS N132N10, N132N17
OPEN PARTS EAF3408.20
OSSCA 06085
PATRON PF1484
PEMEBLA JAPFA-110S
PURFLUX A330
PZL Filters WA30300A
QH Talbros WA6112
QUINTON HAZELL QFA0485
RED-LINE 36NI017
RIDEX 8A0378
RYCO A1203
SAKURA Automotive A-1882
Sakura Filters AU FA-1882
SCT - MANNOL SB014
SOFIMA S 7169 A
Stark SKAF-0060384
STELLOX 71-02011-SX
TECNECO FILTERS AR579-I
UFI 27.169.00
UNIFLUX FILTERS XA1842
WE PARTS 16330
WILMINK GROUP WG1216839
Wix Filters WA6112
Post #971686 19th Nov 2022 1:53pm
I can see now that I had hardly skimmed the surface! Thank you for a useful and possibly definitive list. Thumbs Up
Post #971707 19th Nov 2022 3:59pm
nitram17
I was wondering what's the alternatives to a standard airbox for a puma ?nugget .diy bodge and what else ? Am i being a little simplistic? all you need is a as wide a bore tube from wing inlet preferably sealed ( air sensor)to some sort of air reservoir with a filter in it that fits in the space allocated by original airbox..then a pipe to the turbo/engine....I know its probably more complicated for a aftermarket company to introduce a product to the market but the landrover community is innovation and i think nugget needs a little competition.
I might have a we search for inspiration starting at...
https://www.carbuilder.com/uk/search?q=air+duct
Post #971712 19th Nov 2022 4:59pm
Ianh
I started at topic looking at the options I was aware of. In the end I went with a Nak wintop air intake and a nugget stuff Leo deluxe airbox
https://www.defender2.net/forum/topic82616.html
Post #971716 19th Nov 2022 5:29pm
nitram17
That would have cost you around 700-800 notes? I personally think its overpriced for what you get ..but that's the joys of defender ownership Big Cry what actually are the options?
Post #971743 19th Nov 2022 9:44pm
PCM
Watching this with interest. I’ve also been on the lookout for a sensibly priced well made option to have a bigger bore hose into the side vent and keep the modified standard air box.
I know some clever people have made something that works but I’m not 100% sure I ever would.
Post #971755 19th Nov 2022 10:55pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Success
It's a pain of a job to do and I don't have much skin left on my knuckles.
I'm not convinced this little device does much for water separation. I was out in thick fog/drizzle yesterday and when I took the lid off the air box it was damp inside with some small puddles in the webs.
Ultimately I think I'll fit the Nugget Stuff wing to air box kit, however, there's a few things on the list in front of it.
I'll report back on any difference or not.
Post #971814 20th Nov 2022 3:44pm
Thug
South Africa 2009 Defender 90 Puma 2.4 CSW Indus Silver
Just bit the bullet and ordered the full Nugget Stuff Airbox kit from Wayne, which once installed I'll match to my Mantec RAI.
Post #972133 23rd Nov 2022 12:28pm
dannyragsdale
Papau New Guinea 2012 Defender 110 Puma 2.2 HT Fuji White
Just did this and took me less than 30 minutes. Helps a lot when you have a reciprocating saw. The little fan came out in pieces, but it came out. I can't tell a difference at this point but I'm trusting that it did make a difference since everyone else says it does Laughing
Post #972648 27th Nov 2022 8:48pm
Naks
Me too, it should arrive today/tomorrow, and then will get my indie to fit it.
Will report back afterwards --
Post #972665 28th Nov 2022 5:09am
Thug
2 orders from SA in the same week.
Makes you think that we hang around in the same circles. Laughing
Post #972674 28th Nov 2022 8:17am
steveww
First long drive, to Norfolk and back, over the weekend since removing the little fan thingy. No scientific measurement but I think the pick up from low RPM is much better and overall the throttle response feels smoother.
Well worth the time and skinned knuckles.
Post #972688 28th Nov 2022 9:55am
