Home > Puma (Tdci) > Air box modification - Do it!!
Page 2 of 6 <123456>
I have sealed but standard piping on mine. But it is indeed worth doing.
The Puma is quite thirsty with its air consumption, itโ€™s surprising how much restriction there is in there. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #778530 22nd Jun 2019 5:26pm
Morepower
New Zealand
Bowler did a lovely airbox kit... but it was serious moo-la It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #778823 24th Jun 2019 6:23pm
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
Just managed to disappear out to the garage this evening and removed the impeller thing a ma jig!! ๐Ÿ‘๐Ÿผ
Wont be driving it till the weekend but anything to make it breathe a little better, excited to see if the โ€œlack of feelโ€ bottom end improves
Post #778828 24th Jun 2019 7:47pm
Guy
Sounds like a great mod to improve drivability slightly!
DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped.
**FOR SALE**
SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD.
GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD.
PINGU - '96 Defender 110 300Tdi station wagon. SOLD.
Dream LR - 130 pop top station wagon camper.
Post #778851 24th Jun 2019 9:02pm
Sulisuli
Just done this mod today, every little helps Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #778852 24th Jun 2019 9:11pm
Do remember that the centrifugal separator is there for a purpose and if you remove it and do nothing else you are more likely to end up with a saturated paper air filter element in very wet or humid conditions. Unless you fit a more sophisticated prefilter as part of a more thorough upgrade, you might want to check the condition of your air filter element more often.
Post #778892 25th Jun 2019 6:41am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Thank you Blackwolf, Iโ€™ll certainly remember to do that .
To be honest I didnโ€™t try the new pipe work with the impeller still attached , I probably should have as the larger diameter pipe is what would logically make the biggest difference . Luckily I didnโ€™t have to butcher the pipe work to remove anything so I may try it with it back in . https://www.instagram.com/hustynminepark/
Post #778932 25th Jun 2019 11:32am
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Is there a step-by-step guide for this mod available?
Post #778937 25th Jun 2019 12:08pm
Does anyone actually know the OEM of the Genuine air filters? KEEP CALM AND Drill ON
Post #778955 25th Jun 2019 2:57pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Blimey, old thread...โ€ฆ. Remember doing this mod with Porny back in the day. Putting Dreams on Drives at JLR Solihull..
Post #779013 25th Jun 2019 8:51pm
Sulisuli
Old thread but new owners which is what makes this forum so good, so much knowledge to share. Thumbs Up
โ€˜Have you had any problems since you did yours adafish? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779015 25th Jun 2019 8:56pm
adafish
NO, I meant I was working with Porny on the idea down at IRB at the time. Did a fair few early Puma back then, even his own development 90...Goode old days of R&D , many late nights and rolling road days... Putting Dreams on Drives at JLR Solihull..
Post #779079 26th Jun 2019 10:21am
Roy5695
No problems with my airfilter in 4 years Simon, not with the standard pipe, snorkel, silicone replacement pipe
Or my new 4โ€ pipe setup. Not even a hint of a damp filter. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #779114 26th Jun 2019 3:36pm
No problems here either. KEEP CALM AND Drill ON
Post #779116 26th Jun 2019 3:38pm
diduan
Bulgaria
I removed the propeller-like-thing today. I didn't cut anything, just unhooked it with a screwdriver and took it away. Initially the plan was to remove the complete air box, but after I had it loose I realised that it wont come up because of the air-conditioning. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #820239 19th Mar 2020 3:23pm
