Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
The door came from SP. Non-galvanised.
Joel |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Thanks
Thanks ![]() I would not get bored just looking at that. |
She’s certainly a beaut.
Defender number 5 and I’m finally getting there ![]() Will keep the thread updated as it comes together. Joel |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Dropped the 110 off at the garage Friday morning before a weekend in London and picked it today. 110 in for injector seal replacement, timing check and check injectors in the correct cylinders.
One injector seal showed sign's of leakage, one of the rubber O rings snapped on removal from the injector and the timing was a fraction out. All now sorted. 110 appears to idle smoother and less tappety, also picks up a bit quicker as well. The test will be a long run at weekend for the rally at Ty Croes. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10881 ![]() ![]() |
As Millie has an ongoing problem, i changed the fuel lift pump to hopefully sort the problem out on Friday evening
Old one out .............. ![]() Click image to enlarge New one in .................. ![]() Click image to enlarge All went well for me doing this for the first time ![]() But it did not sort the problem out ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Busy day today with Roy5695
![]() Fitted BAS Hi flow intercooler as well a complete set of BAS silicone hoses and did the airbox mod this combined with last Fridays midpipe replacement means all’s ready for tomorrow’s Alive stage 2 remap ![]() Even before the planned remap tomorrow the difference is “amazing” drive home was fantastic. Thanks again Roy for all your work enjoy your Jack Daniels you have earned it ![]() 2008 SVX 90 2000 XS TD5 90 |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
Did a bit of woodwork in the back ...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge @steve_overland on Insta. 110 expedition vehicle with pop roof |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Love it👍👍 |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2119 ![]() ![]() ![]() |
....A series of Sonic booms heard over Cornwall last night - the first time since Concord stoped flying in over the county .... ![]() Sounds like you had a great day! How easy was the air box modification ? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
Today a little tow job
Wyvern
The airbox mod was simple, says he who watched someone do it, even I could do it ![]() Roy5965 did it as I watched explaining what he did as he went as that was quicker than explaining it for me to understand ![]() Easy enough mod hardest part was the removal of the airbox itself but as we had most of the front end out including the cowling under the fan gave us more space to wiggle the airbox out, the air on pipe gets in the way. The changes in the defenders performance by doing that, the new intercooler, hoses and the mid pipe replacement is amazing, the exhaust note is a little deeper and sounds much nicer. Gary from Alive now has the ecu files from the Defender and will look at them and suggest what needs tweaking to bring together all the tweaks and mods listed above to give more torque etc. The drive is very grin inducing and when Cal said to me your Defender sounds noisier I grinned even more ![]() Previous intercooler stored safely in my garage for you ![]() 2008 SVX 90 2000 XS TD5 90 |
Have you got round to changing your aerial yet? ![]() 2008 SVX 90 2000 XS TD5 90 |
Sounds like its a good job done ! looking forward to seeing the wagon and hearing the noise ! (note to self to bring ear defenders ! ) ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
