![]() | Home > Puma (Tdci) > Regular Diesel & DPF |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Hello,
I just wanted to know if regular diesel would be okay in a Defender 2.2 with DPF ? I know that some cars like the Mercedes Diesels with DPF and ADblue are not compatible and will trigger a CEL Light due to a clogged DPF. I couldn't find any information online regarding the compatibility. Using the EURO diesel over here is 3 times more expensive than regular diesel so I was curious to see what are the implications. Thank you in advance, 2016 Defender 90 Adventure Edition |
Not sure what you mean with the difference between regular diesel and Euro diesel. Here in Europe, all cars, including those with DPF/Adblue, drive on what we consider to be regular diesel, and a smaller number on premium diesel which is just the same thing plus some additives. You cannot buy anything else here than our regular or premium diesel.
What’s different your end? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
Fuel is expensive in Kuwait?? Or is it that Euro Diesel is 30p a Gallon instead of 10p?
![]() Just been to Albania and used 10ppm Diesel called „Euro 5“ or sometimes „blue Diesel“ instead of 50ppm „Euro 4“ or just „Diesel“. Difference in price was just 10% though. |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 579 ![]() ![]() ![]() |
If you looked in the manual you would just find the required Euronorm (EN) standard for the diesel. And you may also find out that diesel up to 3000 ppm can be used. |
Euro Diesel which is the premium diesel over here costs $66 to fill up my Defender, the regular diesel will cost me around $19 and change.
My previous defender 2.2 ROW spec didn't have a DPF and wasn't as sensitive as this newer one which has a DPF, thus after searching around I have decided to decat sans DPF and run a DPF patch file from BAS. 2016 Defender 90 Adventure Edition |
You're not in Europe.
You could just visit a retailer and have you're engine modified in compliance with ROW standard. No big deal. And you're going to obtain an original (professional) ROW ECU remap from Land Rover. Why order a suppliers modifications ? If you ordered two ROW kits from JLR, I'll buy the second one. Be sure of that. |
Its already modified with larger intercooler and remap along with pipping. 2016 Defender 90 Adventure Edition
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
Why don’t you use fuel additive such as Millers? Or is supply an issue for you there? Just an idea. Then you can use regular diesel with it. WeWillWin🇬🇧🇺🇸
The BAS mod is based on European fuel standards. They will not have tested the engine using different foreign fuels. If you want to switch to ROW standard, you'll have to count on Land Rover. If you want to rely on European standards, you may leave as is or get it tuned by some European (e.g. BAS). |
My previous 2013 had 90,000 km on BAS tune was very reliable, fuel additives are not available over here for diesel. 2016 Defender 90 Adventure Edition
Just installed the DPF decat pipe from Allisport & New tune update DPF patch removal from BAS(done remotely via OBD2 port).
I can feel a difference in turbo as the turbo spool is much faster sub 2,000rpm. Very happy ![]() Thinking of doing replacing the mid silencer with an allisport sport version which has less restriction. Pictures to follow soon. 2016 Defender 90 Adventure Edition |
