Home > Puma (Tdci) > Regular Diesel & DPF
SkyFallSilver
Kuwait
Hello,
I just wanted to know if regular diesel would be okay in a Defender 2.2 with DPF ? I know that some cars like the Mercedes Diesels with DPF and ADblue are not compatible and will trigger a CEL Light due to a clogged DPF.
I couldn't find any information online regarding the compatibility. Using the EURO diesel over here is 3 times more expensive than regular diesel so I was curious to see what are the implications.
Thank you in advance, 2016 Defender 90 Adventure Edition
Post #777797 17th Jun 2019 8:47am
ericvv
Not sure what you mean with the difference between regular diesel and Euro diesel. Here in Europe, all cars, including those with DPF/Adblue, drive on what we consider to be regular diesel, and a smaller number on premium diesel which is just the same thing plus some additives. You cannot buy anything else here than our regular or premium diesel.
What’s different your end?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #777821 17th Jun 2019 11:48am
MK
As far as I now you need to use low sulphur diesel. What is the limit for the Defender. I do not know. 50, 15 ppm of S? Puma 110" SW
Post #777875 17th Jun 2019 4:29pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Fuel is expensive in Kuwait?? Or is it that Euro Diesel is 30p a Gallon instead of 10p? Wink)
Just been to Albania and used 10ppm Diesel called „Euro 5“ or sometimes „blue Diesel“ instead of 50ppm „Euro 4“ or just „Diesel“.
Difference in price was just 10% though.
Post #777894 17th Jun 2019 6:08pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Regular Diesel & DPF
If you looked in the manual you would just find the required Euronorm (EN) standard for the diesel.
And you may also find out that diesel up to 3000 ppm can be used.
Post #777939 17th Jun 2019 9:54pm
SkyFallSilver
Kuwait
Euro Diesel which is the premium diesel over here costs $66 to fill up my Defender, the regular diesel will cost me around $19 and change.
My previous defender 2.2 ROW spec didn't have a DPF and wasn't as sensitive as this newer one which has a DPF, thus after searching around I have decided to decat sans DPF and run a DPF patch file from BAS. 2016 Defender 90 Adventure Edition
Post #778241 20th Jun 2019 10:40am
Julie
You're not in Europe.
You could just visit a retailer and have you're engine modified in compliance with ROW standard.
No big deal. And you're going to obtain an original (professional) ROW ECU remap from Land Rover.
Why order a suppliers modifications ?
If you ordered two ROW kits from JLR, I'll buy the second one. Be sure of that.
Post #778242 20th Jun 2019 11:15am
SkyFallSilver
Kuwait
Its already modified with larger intercooler and remap along with pipping. 2016 Defender 90 Adventure Edition
Post #778250 20th Jun 2019 12:45pm
Why don’t you use fuel additive such as Millers? Or is supply an issue for you there? Just an idea. Then you can use regular diesel with it. TheThunder Rolls🇬🇧🇺🇸
Post #778257 20th Jun 2019 1:32pm
Julie
The BAS mod is based on European fuel standards. They will not have tested the engine using different foreign fuels.
If you want to switch to ROW standard, you'll have to count on Land Rover.
If you want to rely on European standards, you may leave as is or get it tuned by some European (e.g. BAS).
Post #778300 20th Jun 2019 6:50pm
SkyFallSilver
Kuwait
My previous 2013 had 90,000 km on BAS tune was very reliable, fuel additives are not available over here for diesel. 2016 Defender 90 Adventure Edition
Post #778355 21st Jun 2019 5:24am
SkyFallSilver
Kuwait
Just installed the DPF decat pipe from Allisport & New tune update DPF patch removal from BAS(done remotely via OBD2 port).
I can feel a difference in turbo as the turbo spool is much faster sub 2,000rpm. Very happy Smile
Thinking of doing replacing the mid silencer with an allisport sport version which has less restriction.
Pictures to follow soon. 2016 Defender 90 Adventure Edition
Post #779788 1st Jul 2019 7:56pm
