Home > 130 > BMW 335D conversion
Page 2 of 3 <123>
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I have been lookin around, and i may just go with a 3.2 TDCI swap. Less adapter plates, but slightly higher investment cost. Plus i could swap in the newer MT82 gearbox, but it will need to be modified to handle the new power output.
I would be getting about 300bhp vs 220bhp from my td5
Post #710859 5th Jun 2018 9:21am
JOW240725
Have you tried search 3.2 tdci, quite a few threads on here, for example http://www.defender2.net/forum/topic52386....conversion
I thought you only got about 240BHP from the 3.2? James
Instagram @suffolk_rovers
Post #710865 5th Jun 2018 9:46am
Naf
I sent a Pm to Steve, lets see what he says...
I am goin from TD5 instead of Puma, so its gonna be a new challenge
Post #710907 5th Jun 2018 2:18pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
http://www.onlinegearboxparts.com/
Adaptor plate is also available so you can use std R380 without having to mod it to fit BMW engine, Not cheap though.
Post #715730 2nd Jul 2018 8:08pm
Pilgrimmick
I’m fitting the BMW 3.0 td6 engine to my130. Tuned to 140 bhp. Should be fitted by end of the month. Report to follow. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #775934 2nd Jun 2019 5:11pm
140bhp seems very low. Do you mean 240? Darren
Post #775942 2nd Jun 2019 6:20pm
Pilgrimmick
Good spot. I was just making sure you were paying attention! 😂 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #776273 5th Jun 2019 12:47pm
JOW240725
I look forward to reading and seeing more Thumbs Up James
Post #776276 5th Jun 2019 12:51pm
excossack
Are you using the standard BMW ECU or a custom one? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #776277 5th Jun 2019 12:56pm
Pilgrimmick
Custom one. I am having the work done by Marcus Of MW Engineering 4x4.
He has done a few now, has custom clutches sorted out to take the power, exhaust templates and the ECU and cooling sorted. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #776289 5th Jun 2019 3:26pm
Zed
Exciting stuff. It needs it's own build thread on here.
Post #776299 5th Jun 2019 4:34pm
mattc
United Kingdom 2005 Defender 90 2.5 TD HT Java Black
I drive a 435d. The thought of my Defender going almost as quick sounds somewhat frightening/fun in equal measures!
Post #776322 5th Jun 2019 7:17pm
miker
You say as quick as, but it still has a kerb weight north of 2 ton, the aerodynamics of a house and the same transmission losses as before Laughing
Post #776340 5th Jun 2019 10:18pm
Pilgrimmick
The L322 Range Rover used the same engine in 175hp form. Although a tad more aerodynamic it was infact a heavier car than the 130, so for me where top speed is irrelevant, but mid range power is desirable then I think it will be a stunning power plant.
A report will follow. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #776358 6th Jun 2019 8:10am
Moneypit
Has anyone done the conversion using the BMW auto box?
Post #776759 8th Jun 2019 8:06pm
Page 2 of 3 <123>
