Home > 130 > BMW 335D conversion |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
Fuel pump in tank? Has the BMW engine the same? Or with the same power/pressure? The same with diesel filter. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
3rd Jan 2018 1:08pm |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
I may keep the in tank pumo, but i have to upgrade the secondary pump to one from a Freelander td4.
3rd Jan 2018 1:30pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
will be interested to see how well it goes when complete BMW diesels are stonking DEFENDER 90 TDCI XS,
3rd Jan 2018 5:21pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
Harness adapter for BMW
Throttle pedal from Mini D in terms of ecm - is it that straight forward? or will the ecm side of things make this almost impossible? good luck whatever and look forward to seeing progress in due course |
3rd Jan 2018 5:55pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Bored of the TD5 already?
3rd Jan 2018 6:22pm |
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 169 |
Wow, I would guess the wiring would be the biggest hurdle with this, I know how complex they can be, good luck and very interested in your project, they are a cracking engine.
4th Jan 2018 8:07am |
seatosky Member Since: 16 Jan 2018 Location: Vancouver Posts: 2 |
Sounds very tempting...keep us posted!!
25th Jan 2018 5:57am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 763 |
I'm hoping for a project / build thread on this conversion
25th Jan 2018 6:21am |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
I had a 2014 335D, absolutely amazing engine amd drivetrain, stupidly quick for 40+ MPG!
Good luck with the project, it will be amazing. |
25th Jan 2018 6:54am |
you've upgraded the axles/drive shafts etc but will the UJ's be ok ?
awesome conversion |
25th Jan 2018 12:38pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Might help you asking on here https://m.facebook.com/groups/1106830676068639 good luck with the conversion.
3rd Feb 2018 12:00am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
This will be a beast 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
3rd Feb 2018 9:38am |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 |
Remember reading somewhere that rallyraid Uk do a loom conversion to run the factory immobilizer or delete it.
6th Mar 2018 6:56pm |
Yes they are a strong powerful engine, I run a 435d everyday and it’s fast and economical. Some clever person should be able to sort out the EWS and harness, I did install a M52 motor in an old E30 and had a harness and ECU made to delete the alarm and immobiliser, keep the updates coming and have a look on facebook where loads of guys are doing M57 conversions into defenders.
30th May 2018 7:08am |
