Home > Puma (Tdci) > Air box modification - Do it!!
Page 1 of 6 123456>
Dobby
Just got round to doing the air box modification, as per the thread below.
Well worth doing it if you haven't already. I noticed an instantly smoother and responsive engine. Not quite a remap like change, but a much better engine for sure.
https://www.defender2.net/forum/topic25864.html
Why JLR thought it was a good idea to put that lump of plastic trash impeller in the pipework is beyond me.
Dobbs
Post #773620 17th May 2019 8:09pm
They thought it was a good idea because it dries the incoming air to stop the filter disintegrating and the resultant unfiltered air knackering the engine!
I have to say that removing it and fitting a properly engineered sealed induction system with a proper prefilter does make a huge difference to drivability though!
Post #773630 17th May 2019 8:53pm
Dobby
That I can understand. Looking at the 'bits' left over, I can see the impeller 'could' spin the wet air enough to fling the water to the sides of the tube in the bottom of the box. There's a long lip on the end of the tube, under which is the drain. So aerodynamically it's a bit of a spin cycle for the incomig wet air. But I reckon that's only designed to "help" (as the lawyers will say) to stop the filter getting wet.
Post #773641 17th May 2019 9:25pm
I did mine. You’ve got to bear in mind the impeller could get jammed up with debris too. A garage had one in the other day with the impeller jammed up with leaves, which significantly reduced performance as you can imagine.
If they had to put one in they could have at least increased the diameter of the inlet to reduce the constriction but still have it in place. Mines been done about 5 years now, never had a problem at all.
I do prefer to change the filter annually though ideally. WeWillWin🇬🇧🇺🇸
Post #773650 17th May 2019 10:05pm
Apologies for the typos there. Using phone. Rolling Eyes
*Now corrected.* WeWillWin🇬🇧🇺🇸
Post #773652 17th May 2019 10:08pm
Co1
Did mine a while ago as well. Bit of a fiddle but a noticeable difference for sure.
Post #773674 18th May 2019 8:07am
Roy5695
Did mine years ago, coupled with a 4 inch intake pipe and a silicone airbox to turbo pipe the difference is massive! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #773675 18th May 2019 8:10am
Zed
Worth doing and definitely feels an improvement as opposed to expensive intercooler and exhaust mods/upgrades which IME give no usable gains. However don't expect miracles, as Ian says in that thread:
Quote:
It's gives the potential of 11nm with other modifications to the inside of the air box... especially to the internal trumpet.
However it will never give more max torque than the engine one calibration is set to give. But will aid engine performance and response over the whole rpm range... and thus help it to make max torque.
I think there are now replacement parts available for those who don't want to do the butchering themselves or need to return to standard in case of warranty work.
Post #773677 18th May 2019 8:25am
The trouble is you've got to be careful you don't go so far as you go though the airbox structure its self.
Definitely a go to take time and patience over and if it is done before tuning as mine was it is well worth mentioning any mods you have so it can be taken into account pre tune. WeWillWin🇬🇧🇺🇸
Post #773704 18th May 2019 12:35pm
PCM
In respect to the replacement parts v home made kits. I've found a puma kit by ozzy Nugget stuff one and there is also a Naka one but it seems is only for a TD4.
There was reference from Pete@BAS that they were thinking of making one but nothing on his website.
ANy other kits out there that anyone knows of? . Nugget one seems fine but expensive. Has BAS made any progress on this yet? Pete?
https://www.firstfour.co.uk/defender-puma-sealed-air-system.html
Post #773796 19th May 2019 2:12am
Landborgini
United Kingdom 2014 Defender 110 Puma 2.2 HT Corris Grey
Noticeable difference
Fitted Alive boost pipes this morning and whilst exposed thought I’d have a look at this airbox mod. Took about 45 minutes. Difference: a noticeable difference in 1st and 2nd seems slightly less holding back and more linear is the best way to explain.
Multi tool was my weapon of choice. Propellor/impeller tapped straight out from the inside. Not done the intake pipe yet, I’ll wait and see.
Good call Thumbs Up
Post #773884 19th May 2019 4:02pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Can I mod my TD5 2001 90 air box? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #773904 19th May 2019 7:35pm
bear100
Done mine today, I was sceptical but an immediate difference! Worth the 30mins to do it.
I used a hot knife, I have a gas soldering iron which came with a few attachments, hot knife was one of them and it worked a treat best £15 I spent in Maplins!
 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #773905 19th May 2019 7:51pm
Zed
Allisport do a very nice replacement for TD5's.
Post #773913 19th May 2019 9:07pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
After fitting today, I can absolutely confirm that upgrading to the nugget air intake kit is a fantastic upgrade . Also removed the impeller. It just baffles me as to why a less restricted hose was not put on by Land Rover .
Instant improvement in response from the throttle and just a far smoother ride in every gear and up through the Rev range .
Frankly I think it’s made and equal difference to the BAS remap . https://www.instagram.com/hustynminepark/
Post #778524 22nd Jun 2019 6:06pm
Page 1 of 6 123456>
