Home > Maintenance & Modifications > LOF POWERspring pedal assist
Page 7 of 14 <123 ... 678 ... 121314>
Sulisuli
Well I have to say I’m impressed, I was sceptical I would notice a difference but I certainly have,very impressed and would totally recommend this, might well be the best £25.00 I have spent on the Defender Thumbs Up thanks Luke. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #767071 5th Apr 2019 7:13pm
Co1
Had mine for a few weeks now and the improvement is vast. Not just the lightness of the pedal itself, but because of it, gear changes are much smoother and slicker. Wouldn’t hesitate to recommend.
Post #767073 5th Apr 2019 7:19pm
Sulisuli
Have to agree Co1 reference the gear change, never thought a spring could make that much difference Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #767077 5th Apr 2019 7:32pm
Screbble
Ditto ^^^ Thumbs Up
Well worth the pennies.
It's certainly helped ease the pressure off my 'dodgy' leg.
Post #767081 5th Apr 2019 8:10pm
hank
I fitted one of these recently. After faffing about with compressing in a vice, cable ties, string, lengths of wood etc I resorted to a pair of pliars and brute force.
Job done in ten minutes and one hell of an improvement Thumbs Up > 110 XS Double Cab
Post #769564 22nd Apr 2019 9:25am
PCM
I’m now a believer.
Couldn’t see it making that much difference but I was wrong.
Easily the best few quid spent so far. That’s on a 2.2 puma.
Thumbs Up
Post #778288 20th Jun 2019 6:31pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Just fitted one to my 2.2, first impressions i didnt think there was much difference, took it for a short drive up the lane, it is slightly lighter, a longer drive will tell this.
25 mins to fit once i found the right tools to use, a very long handled pair of pliers, give much more room to put pressure on the spring and it went straight in one side, then use the mole grips to hold the side already in securely in place, whilst pushing the other side in.
Post #778401 21st Jun 2019 1:28pm
LUKE-FITZSIMONS
United Kingdom 2011 Defender 110 Puma 2.4 CSW Santorini Black
Hey guys,
Really glad with how this thread is going!
Thanks for all of your kind words - Fitting can be a B*tch without the right kit (long nose molegrips are my favourite)
We will be at Billing LR show this weekend, if anybody is struggling I am happy to help fit theirs one evening!
Always nice to read such positive feedback!
Post #778925 25th Jun 2019 12:00pm
Martin
Site Admin
Good promo for you, care to join up as an advertiser proper?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778926 25th Jun 2019 12:08pm
LUKE-FITZSIMONS
Sure thanks Martin,
I did drop you an email a while back, please feel free to contact me!
Post #778929 25th Jun 2019 12:28pm
Martin
Site Admin
Eek I'll search it out Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778933 25th Jun 2019 12:33pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
How did I miss this thread.......ordered and awaiting arrival.
Post #779016 25th Jun 2019 10:31pm
macventu
I fitted this new spring last night. I'd recommend using the vice method to tension (almost fully) the new spring, then use metal cable ties as per the link below. Then the spring can be positioned fairly easily before cutting the metal ties.
Probably 30mins in total.
https://www.amazon.co.uk/Pack-Premium-Stai...07CQ2K4HJ/
Post #779351 28th Jun 2019 11:28am
Sulisuli
that might be a new record time for fitment Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779357 28th Jun 2019 11:55am
LesDef
Gidday,
Please allow me to describe a fitting method that worked for me. Wear safety glasses.
Using the cable tie method, fitted exactly as shown in earlier photos but a little closer to coils to clear bushes.
Clutch pedal in up position install spring into stationary pedal box tab bushes in a central position.
Depress clutch pedal and swing spring into start of pedal bush position.
While pedal is depressed, install a round bar (short extension bar) through both spring coils, then slowly allow pedal to travel out.
Pedal will be held slightly down by bar and spring wedged into start of pedal bush.
Cut each cable tie, spring should be pulled into pedal bush.
Depress clutch pedal and withdraw bar, remove cable ties.
Squeeze pedal box tabs in.
I didn't remove top tab.
Good luck.
Post #782499 22nd Jul 2019 3:53am
