Home > Maintenance & Modifications > Rear Half Shaft Replacement
Page 5 of 9 <123456789>
I find the front bushes last and last but the rears don't.
In fact I'd say they wear at about twice the rate. TheThunderRolls🇬🇧🇺🇸
Post #762409 7th Mar 2019 8:43pm
Grenadier
Yes, pretty shocking. I've got a full set of new bilsteins going in, plus rear ARB, so will do all bushes at the same time. Decided after a lot of advice on the forum to go OEM. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #762459 8th Mar 2019 7:32am
I find that (genuine) rear bushes typically last only about 25k miles. Genuine seem to be much better than aftermarket, too.
Post #762462 8th Mar 2019 8:51am
Grenadier
If that's the case, there must be quite a number of vehicles out there with owners who don't know/care or aren't mechanically minded, with shot bushes. That's probably no more than a two year window for most, average usage? Monsieur Le Grenadier
Post #762463 8th Mar 2019 8:58am
donmacn
^^^^^ I think this is highly-likely. Driving along with lots of clunks and bangs.... Oh, it's just a LR, it's meant to sound like that... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #762465 8th Mar 2019 9:01am
I generally replace them annually, just before the MOT (but typically I do 25k between MOTs). They're very cheap to replace and it's good to have new parts on for the MOT, it makes the vehicle look cared-for.
Post #762483 8th Mar 2019 10:55am
At least they aren't expensive but it's more of an annoyance more than anything having to do them time wise.
Makes you wonder LR or anywhere else could use it to develop a more expensive job out of it if so one was not aware of what the problem was.
Change a couple of bushes pay a few hundred pounds and done. TheThunderRolls🇬🇧🇺🇸
Post #762518 8th Mar 2019 4:40pm
donmacn
Just coming back to the original question, almost, what's the consensus on rear half shafts on a 110?
Are the Bearmach/Britpart one piece ones up to the job on a 110? It tows a boat regularly, and then goes offroad/low box to launch and recover it, but that's about as extreme as it gets. Donald
in the past..
Post #762971 12th Mar 2019 1:17am
Landymatt
I’m about to try the blue box one piece half shafts, even though it appears too early days for people to have seen potential early wear.
Question - should you use Loctite on the 5 flange bolts?
I read that you can expect there to be Loctite in there when you remove the bolts, but haven’t read that you should reapply it.
Advice welcome,
Matt
Post #764084 17th Mar 2019 10:25pm
Loctite is not required if you do them up to the correct torque. Darren
Post #764087 17th Mar 2019 10:40pm
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
Will these fit a rear sailsbury axle?
Post #765411 26th Mar 2019 7:49am
No, I'm afraid not. Darren
Post #765418 26th Mar 2019 9:06am
Grenadier
I suppose it depends on the quality of the weld between shaft and flange, and the quality of the shaft itself, there’s very little to them otherwise. So if the shaft and flange or no less worse than OE, and the weld is good, well.....should be fine. I’m considering them.
Or this more Grenadier over simplifying? Monsieur Le Grenadier
Post #765537 26th Mar 2019 7:59pm
If they're welded give them a miss. Single piece shafts should be forged in one piece.
Post #765539 26th Mar 2019 8:18pm
Grenadier
Rolling with laughter Rolling with laughter Rolling with laughter
I’m so simple Monsieur Le Grenadier
Post #765540 26th Mar 2019 8:20pm
