Home > Maintenance & Modifications > Rear Half Shaft Replacement
Page 9 of 9 <123456789
Bluest
My own opinion of spring lock washers is that they do little to nothing to prevent bolts from loosening. I've done quite a bit of reading up after I had some come loose on a machine. There is quite a lot of information online that shows they don't work to prevent loosening
Nord Lock washers are supposed to be good, but they are expensive. However, I also saw a test that shows they don't work on some high grade bolts of hard material as the teeth don't bite into the bolt head.
I like thread lock used in moderation. 2007 110 TDCi Station Wagon XS
Post #844758 19th Jul 2020 7:45pm
