Home > Maintenance & Modifications > Rear Half Shaft Replacement
Page 3 of 9 <123456789>
Grenadier
LandRoverAnorak wrote:
Grenadier wrote:
Do these look right as the Disco upgrade?
Description: LANDROVER DISCOVERY 300 TDI V8 REAR OFFSIDE 24 SPLINE HALF SHAFT THIN FLANGE
I'm not sure that ex-Disco ones are right for a 110. It's only in more recent years that the part numbers for both 90 and 110 have been the same. In the 1990's, they were different and the Disco half shafts were shared with the 90 of that era.
Thanks LRA. I think best avoided in the short run then, unless Joe shows they work Smile Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #761803 4th Mar 2019 7:09am
I'm sure that they'll fit. I just don't know if they have the same rating. This is all just supposition based on the fact that LR used them in the 90 but not the 110, though. Darren
Post #761810 4th Mar 2019 8:00am
Grenadier
Given you ‘know your onions’ when it comes to Def maintenance, you may have seen on another thread that I have some drivetrain slack. Initial thoughts start with flanges/half shafts, but some have said the diff. Ive just done a 30min drive and noticed (for the first time) on a flat road, 90kmh, not pushing hard, that when i lifted off the accelerator and reapplied on the accelerator, that there is a very slight but still noticeable clunk on engagement. Any ideas if this is likely to be flange or diff? Monsieur Le Grenadier
Post #761851 4th Mar 2019 12:16pm
Could be flanges, diff, A-frame balljoint, propshaft uj, centre diff, transfer box, output adaptor shaft, clutch, or something rolling about in the back.
My first suspect all things being equal would be the balljoint.
Post #761855 4th Mar 2019 12:37pm
Wot he said Laughing Darren
Post #761856 4th Mar 2019 12:46pm
MK
As for the Disco V8 one piece halfshafts they do fit. They are 28mm diameter compared to 32ish mm std Defender halfshafts. Puma 110" SW
Post #761860 4th Mar 2019 12:58pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
As I don't go off road (except by accident), I doubt I'll be able to break the Disco's shafts.
Post #761862 4th Mar 2019 1:13pm
I bet you can!
Post #761863 4th Mar 2019 1:24pm
Joe the Plumber
Now I'M getting worried...!
Post #761891 4th Mar 2019 4:51pm
Co1
Any tips on the best way to check for play in the a frame ball joint? Mine has had the half shafts done but I still get an audible clunk when braking or accelerating.
Post #761905 4th Mar 2019 6:32pm
It can be difficult!
-GoPro under the car and make it clunk.
-Replace the joint and see if it stops.
It is often very hard to detect movement by traditional prybar techniques.
Post #761913 4th Mar 2019 6:54pm
Damper bushes are worth checking too, especially in the rear I've known those to cause a few issues and you'd neve think it would be them.
Especially the rear lowers.
Worth checking as some of these things are the cheapest too. Chillin In The Backwoods🇬🇧🇺🇸
Post #761916 4th Mar 2019 7:07pm
Grenadier
Clutch is new, albeit I'm not liking it as much as the original (it is still OE), as it's noisier than the last and not nearly as smooth. Output shaft was also changed at the same time. Based on those two items being tackled, I did wonder at the transfer box, but the noise and clunk seem to come from further back. Rear right specfically, where I think the damper is failing and is the reason I have bought the a new set of Bilsteins. I'll check the half shafts for W&T, but I'm wondering with new dampers if I just change the a-frame ball joints, flanges and bushes all at the same time. Monsieur Le Grenadier
Post #761973 5th Mar 2019 6:55am
donmacn
Not so long ago, I was dealing with the same thing. A knock from the rear that had developed quite suddenly.
I was away from home, suited and booted, so unable to start guddling about under the car. Because the shocks were new (not fitted by me though) I was thinking 'A frame balljoint' and asked some questions here about that.
Got home, underneath the car with a pry bar, but the cause was really obviously the NS rear, lower shock bush. It was a long way from tight, and looked like someone had mangled the thread trying to fit it.... badly.
I managed to get a grip on the shock, and nip up the nut, and the knock disappeared. It sounded like something much more substantial and heavy than a rear shock bush.... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #761988 5th Mar 2019 8:44am
Grenadier
Guddling, now there’s a good word.
Mine definitely sounds and feels more like ‘slack’ tightening up on drive, than a clunk or knock. I’ll listen again and see if I can be any more precise. Thumbs Up Monsieur Le Grenadier
Post #761995 5th Mar 2019 9:25am
