Home > Puma (Tdci) > Puma TDCi problem |
jasonshum Member Since: 10 Jun 2011 Location: Hong Kong Posts: 13 |
We saw the same problem occur? |
10th Jun 2011 6:44pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
i have recently changed my fuel filter and that has made things run smoother, not sure if thats your problem, just a thought.
11th Jun 2011 12:35pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 |
What's happening? Can't tell from just a video of the rev counter....! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Jun 2011 1:03pm |
should be:
1. mass meter 2. camshaft position sensor 3. engine rev sensor 4. fuel filter 5. what else? - look if during the "problem" the VVT actuator is moving in the same manner - try to disconnect the battery for 1 or 2 hours (ECU RESET) and then test again - see with a voltmeter if the tension on the battery are fluctuating like the engine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 11th Jun 2011 1:35pm. Edited 1 time in total |
11th Jun 2011 1:32pm |
up and down itself Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
11th Jun 2011 1:34pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
I bet for stuck EGR Puma 110" SW
11th Jun 2011 2:05pm |
Also should be..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
11th Jun 2011 5:19pm |
But the problem is only in the open A / C air conditioning
12th Jun 2011 4:06pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Do you mean you only get this problem when the Air Con is ON If that is the case then I would get the Air/Con system Pressure tested. It could be that it is low on refrigerant or even over full and the Air/Con is switching on an off frequently thus altering the engine load frequently leading to the engine idle speed oscillating. |
12th Jun 2011 4:29pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
I suspect its the engine objecting to the music !!
sorry couldn't help that |
12th Jun 2011 8:15pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
13th Jun 2011 7:25pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
alternator failing did that on a 300tdi disco i had Mike
13th Jun 2011 8:23pm |
