![]() | Home > Puma (Tdci) > Puma TDCi problem |
jasonshum Member Since: 10 Jun 2011 Location: Hong Kong Posts: 13 ![]() ![]() |
We saw the same problem occur? ![]() ![]() ![]() |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i have recently changed my fuel filter and that has made things run smoother, not sure if thats your problem, just a thought.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
What's happening?
should be:
1. mass meter 2. camshaft position sensor 3. engine rev sensor 4. fuel filter 5. what else? - look if during the "problem" the VVT actuator is moving in the same manner - try to disconnect the battery for 1 or 2 hours (ECU RESET) and then test again - see with a voltmeter if the tension on the battery are fluctuating like the engine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 11th Jun 2011 1:35pm. Edited 1 time in total |
up and down itself Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
I bet for stuck EGR Puma 110" SW
Also should be..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
But the problem is only in the open A / C air conditioning
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Do you mean you only get this problem when the Air Con is ON ![]() ![]() ![]() If that is the case then I would get the Air/Con system Pressure tested. It could be that it is low on refrigerant or even over full and the Air/Con is switching on an off frequently thus altering the engine load frequently leading to the engine idle speed oscillating. ![]() ![]() |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
I suspect its the engine objecting to the music !!
sorry couldn't help that ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
alternator failing did that on a 300tdi disco i had Mike
