Home > My Defender > What Did You Do In Your Defender Today |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Will run a chain lock through the wheel. Im afraid thatโs the only security available for these wheels.
28th Jan 2019 10:03pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Will this work?
https://www.4x4overlander.com/product/defe...protector/ 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
28th Jan 2019 10:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
That looks good but I'd be concerned about added weight, mine is heavy enough as it is.
If you do run any lock though it like a cable type, make sure all areas of it in contact with the finished surface are protected with a soft neoprene or foam or similar or you could easily find the paint surface damaged. Most have a splatic finish but even then it's not really soft as such. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Jan 2019 10:08pm |
Iโm thinking something like this. At home I have a U lock on my bike. Will try that to fit otherwise will get one of these.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2779180621 |
28th Jan 2019 10:11pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Great that you are looking into it Clayton.
28th Jan 2019 10:38pm |
Yeah, that's the type I have got on the shelf ready to fit sometime.
I'd fit something like this over the top: https://www.ebay.co.uk/itm/2x-Black-MTB-Bi...Swv7pbzYN- Obviously check internal dia but that sort of thing would protect the wheel surfaces from abrasion.[/url] KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Jan 2019 10:50pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 |
Fitted a new radio
Quality metal front and dials - looks good and is in keeping with Landy - not too flash Click image to enlarge Excellent DAB reception - even with the original Aerial Very good BlueTooth for audio streaming Very quick phone pairing and quality sound for phone calls Click image to enlarge Also bought a pair of Mud A Pillar Trim - to allow more room for routing cables - and installed the external phone mike into the top Click image to enlarge Fitted the GPS under the plastic wing top cover - good satellite reception Click image to enlarge I know the screen is small for SatNav - but if you listen to the commands you don't need to watch the screen - I have a large dash mounted SatNav for when I need more detail or when using MemoryMaps I also know its expensive but I am not going to justify the purchase any more than I need to justify owning a Defender |
30th Jan 2019 2:01pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Order arrived from JGS
Replaced the viscous fan Started looking at the hard start from cold. (not been started since Friday after coming home from work & briefly started last night morning eve) Checked glow plugs all measured between 1.6kohms and 1.9kohms from the tip to a earth wire. Pulled on plug and tested - glowed red for a good 20-25mm from the tip. Will check the others tomorrow but suspect they are OK. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Jan 2019 6:36pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
looking good. what are the two flaps hiding (bottom right and left)? |
30th Jan 2019 6:42pm |
One is for an SD card and the other is a USB connection
30th Jan 2019 6:57pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3343 |
Looking good boode.
30th Jan 2019 7:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
Have you ever changed the injector seals? |
30th Jan 2019 8:02pm |
I like that. What is it, and how much was it please. |
30th Jan 2019 8:04pm |
Probably only when the head gone done around 5+ years ago? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Jan 2019 8:32pm |
