Page 1170 of 1380 <123 ... 116911701171 ... 137813791380>
L110CDL
Michaelkan wrote:
Installed a mantec snorkel today and fitted a bowler spare.
Very nice Thumbs Up
Have you got any security on that spare wheel Question 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #754650 28th Jan 2019 9:40pm
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Will run a chain lock through the wheel. Im afraid thatโ€™s the only security available for these wheels.
Post #754657 28th Jan 2019 10:03pm
Sulisuli
Will this work?
https://www.4x4overlander.com/product/defe...protector/ 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #754658 28th Jan 2019 10:05pm
That looks good but I'd be concerned about added weight, mine is heavy enough as it is.
If you do run any lock though it like a cable type, make sure all areas of it in contact with the finished surface are protected with a soft neoprene or foam or similar or you could easily find the paint surface damaged.
Most have a splatic finish but even then it's not really soft as such. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #754661 28th Jan 2019 10:08pm
Michaelkan
Iโ€™m thinking something like this. At home I have a U lock on my bike. Will try that to fit otherwise will get one of these.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2779180621
Post #754663 28th Jan 2019 10:11pm
L110CDL
Great that you are looking into it Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #754669 28th Jan 2019 10:38pm
Yeah, that's the type I have got on the shelf ready to fit sometime.
I'd fit something like this over the top: https://www.ebay.co.uk/itm/2x-Black-MTB-Bi...Swv7pbzYN-
Obviously check internal dia but that sort of thing would protect the wheel surfaces from abrasion.[/url] No Guts, No Glory.
Post #754673 28th Jan 2019 10:50pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Fitted a new radio Very Happy
Quality metal front and dials - looks good and is in keeping with Landy - not too flash
Excellent DAB reception - even with the original Aerial
Very good BlueTooth for audio streaming
Very quick phone pairing and quality sound for phone calls
Also bought a pair of Mud A Pillar Trim - to allow more room for routing cables - and installed the external phone mike into the top
Fitted the GPS under the plastic wing top cover - good satellite reception
I know the screen is small for SatNav - but if you listen to the commands you don't need to watch the screen - I have a large dash mounted SatNav for when I need more detail or when using MemoryMaps
I also know its expensive but I am not going to justify the purchase any more than I need to justify owning a Defender
Post #754977 30th Jan 2019 2:01pm
excossack
Order arrived from JGS Smile
Replaced the viscous fan
Started looking at the hard start from cold. (not been started since Friday after coming home from work & briefly started last night morning eve)
Checked glow plugs all measured between 1.6kohms and 1.9kohms from the tip to a earth wire.
Pulled on plug and tested - glowed red for a good 20-25mm from the tip. Will check the others tomorrow but suspect they are OK. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #755030 30th Jan 2019 6:36pm
Caterham
looking good. Thumbs Up
what are the two flaps hiding (bottom right and left)?
Post #755032 30th Jan 2019 6:42pm
boode
One is for an SD card and the other is a USB connection
Post #755040 30th Jan 2019 6:57pm
Zed
Looking good boode.
Post #755050 30th Jan 2019 7:26pm
landy andy
Have you ever changed the injector seals?
Post #755077 30th Jan 2019 8:02pm
landy andy
I like that. What is it, and how much was it please.
Post #755083 30th Jan 2019 8:04pm
excossack
Probably only when the head gone done around 5+ years ago? 1999 Defender TD5 110
Regards
John M0VAZ
Post #755099 30th Jan 2019 8:32pm
