Home > Maintenance & Modifications > Is it worth upgrading the intercooler? |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3327 |
Unlike other performance specialists Pete @ BAS is very honest about the real world benefits of intercoolers, exhausts etc. and provides actual data not waffle to back it up. Some of the stuff I've heard from other outfits is frankly laughable. Bowler also tell it like it is. If folks are serious about actual performance upgrades and not just bolting on shiny new things then a visit to the dyno could be worthwhile. Probably save some money also. |
21st Jan 2019 7:06pm |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 |
I should have qualified my statement: under normal loads, you will not see a reduction in engine temp by fitting a larger intercooler. Of course if the engine is working hard under a sustained load, a larger intercooler will somewhat help keep the EGT lower, and hence the operating temperature lower. But again, this is not the primary purpose of the intercooler. |
21st Jan 2019 9:16pm |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
These conversions are fully tested and carefully engineered. Because we do not substantially increase engine loads, by offsetting any increase in boost pressure with reduced air temperature and also by increasing volumetric efficiency without resorting to increased RPM, it is not necessary to carry out costly internal engine modifications, which can lead to long-term reliability problems. By having a range of conversions, we are able to tailor each more closely to every customers requirements whether it be for towing, off-road or fast motorway use.
Our intercooler systems substantially improve performance with optimum thermal efficiency and fuel consumption, so smoke emissions are low and any additional loads on the engine are very small. |
22nd Jan 2019 10:40am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8088 |
Tolley, is that you as a supplier, or are you quoting something from somewhere? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Jan 2019 10:52am |
Don't know if he is also a supplier but the text is taken from here: http://www.allardturbosport.co.uk/index.php?page=land-rover |
22nd Jan 2019 11:31am |
No sorry not supplier yes taken from allards when I had mine done.
22nd Jan 2019 2:50pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2303 |
In one of BAS’s posts on here he says that with his map you can add an intercooler afterwards, the sensors will sense the lower charge temperature and the map will adjust automatically > 110 XS Double Cab
22nd Jan 2019 3:44pm |
