Home > Maintenance & Modifications > Is it worth upgrading the intercooler?
stephan123
Hi,
Currently have the Bowler Stage 1 tune with no other modifications to the engine. Considering upgrading the intercooler but wanted to ask if it will make any noticeable difference. I don't tow or use the car to transport heavy load and 90% of the usage is in town driving. In terms of options it seems that Alive and BAS are the two to go for. Would have liked to get one from Bowler to keep things consistent but doesn't seem like they do one...
Post #752595 20th Jan 2019 1:38pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Bowler use a bespoke PWR intercooler for their Stage 2 upgrade and desert spec. Pricey but probably the best you can buy.
Whether it's worth upgrading for the use you describe is debatable.
Post #752596 20th Jan 2019 1:43pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Allisport do them .
Post #752599 20th Jan 2019 2:26pm
landy andy
I found fitting the ultimate intercooler from Alive made no difference at all to my tuned Tdci.
Post #752625 20th Jan 2019 4:35pm
bankz5152
Bigger IC = cooler/more dense air = more torque in basic terms. Instagram @defender_ventures
Empire Tuning - Agent
Post #752642 20th Jan 2019 5:36pm
Likeomg
Did you have the map tweaked utilize the bigger intercooler?
Post #752717 21st Jan 2019 6:25am
hank
Very interesting! > 110 XS Double Cab
Post #752723 21st Jan 2019 7:28am
grafty99
Intercooler alone will make little to no difference without the supporting engine calibration Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #752726 21st Jan 2019 7:51am
landy andy
Yes, map done, swapping exhaust made much more difference. This was on a Tdci.
Post #752733 21st Jan 2019 8:29am
Likeomg
Interesting, I found it made a noticeable difference... IMO less than the exhaust? Shocked
I have a full sports exhaust with no cat too...
This was all before hybrid turbo too
Times like this i think sticking the car on the dyno and actually seeing what it's doing makes the most sense...
Post #752736 21st Jan 2019 8:41am
hank
BAS website says...
Quote:
We insist on thinking about fitting an up-rated Performance Intercooler to help maintain a lower cooler charge and air intake temperature when cars are worked hard or for long periods. This is especially important when working at high engine rpm or road speeds and especially so when used in hot country’s and climates. High exhaust gas temperatures and air intake temperatures can reduce the life of the engine and related components if low temperatures are not maintained.
Key words being "thinking about" and "important when working at high engine rpm or road speeds and especially so when used in hot country’s and climates" > 110 XS Double Cab
Post #752737 21st Jan 2019 8:54am
ericvv
I have just the standard tune, but I do have the Entreq intercooler which is identical to the Alive Tuning ultimate intercooler. No noticeable increase in performance, but the idea of lower air intake temps, i.e. lower engine running temps gives peace of mind in the summer. And together with the PEL500110 soft spring 82° thermostat the risk of overheating is sharply reduced which is a good thing.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #752744 21st Jan 2019 9:41am
redline
Switzerland
I don't think that upgrading the intercooler will have any effect on the engine operating temperature. Any such benefit - if measurable, is incidental.
Post #752809 21st Jan 2019 4:29pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I feel there was no benefit then surely there'd be no benefit of fitting an intercooler at all... I wouldn't expect a performance increase but I just thought it was healthier to have the lower intake temps on a tuned engine.
Post #752816 21st Jan 2019 5:08pm
JOW240725
I have the BAS hi-flow IC, but had it fitted with teh BAS 170AB remap so can't comment on if you feel any difference. I was recommended it as I tow, but Pete said it wasn't essential if not towing. However, i felt increasing power by 40% the engine must benefit from the extra cooling, not necessarily in performance but for longevity? Good oppourtunity to change to silicone hoses too... where does it stop Shocked James
Instagram @suffolk_rovers
Post #752827 21st Jan 2019 5:54pm
