![]() | Home > In Car Electronics > Blown fuse or not? |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 ![]() ![]() |
Just blown a fuse when inserting a bulb into the courtesy light... radio stopped working also but all fuses are OK. Any ideas welcome!
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Happened to me too. Interior light and radio on same fuse. It will almost certainly be a blown fuse. Swap over the fuse for these circuits. Can't remember which one but in main fuse box.
Have tested every dammed fuse in the box and all good! Interior light, radio, clock not working. Trip resets ever time the ignition is off. Worth mentioning that when the fuse or whatever blew, I'm sure I felt through my arse sat on the drivers seat. Cant imagine there is a solenoid in line...
do you have multimeter to check for dc voltage in the cct
![]() ![]() Off to stand in a corner for a while.... |
go on at lest you sorted now
I'm really curious now.
Were you looking in the wrong fuse box or something? |
paulas Member Since: 23 Nov 2018 Location: cheshire Posts: 23 ![]() |
what was it I have the same problem, fitted new bulb and radio, clock, interior lights don't work and tacho resets but fuses seem ok.
make shore you voltage to and from the fuse
also the needles on the fuel gauge and rev counter don't return to zero ??
also check the earthing battery to chassis to transfer box
2.4 or 2.2
![]() also check fuse 30 and 15 for 2.4 / fuse 4p and 29p for 2.2 and voltage supply too at the fuse ![]() Last edited by dorsetsmith on 23rd Jan 2019 9:34am. Edited 2 times in total |
thanks its a 2.4, strange but I when I was knelt on the passenger seat changing the bulb I noticed small amount of smoke come from the side of the seat and electrical smell.
fuses seem ok. I had a new pioneer system put in a week ago. Don't suppose that has anything to do with it, would there be a separate fuse? forgive me if I am talking rubbish but I am not electrically savvy!
