Home > In Car Electronics > Blown fuse or not?
Page 2 of 2 <12
dorsetsmith
you starting battery is under your passenger seat
Post #753125 22nd Jan 2019 4:36pm
paulas
yeh I checked in there cant see anything wrong or burnt, shorted out
Post #753130 22nd Jan 2019 4:44pm
dorsetsmith
heated seat Question
Post #753134 22nd Jan 2019 5:14pm
paulas
they still work
Post #753141 22nd Jan 2019 5:30pm
Martin
Site Admin
The fact the gauges don’t return to zero points at the fact that the permanent supply to the gauges is no longer there.
I don’t have the diagrams to hand tonight otherwise I would give you the fuse number to check. So check the fuses again - I think you have blown the one which supplies the gauges.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753248 23rd Jan 2019 12:36am
Martin
Site Admin
On a 2.4 Fuse 30 under steering wheel is permanent supply to radio, gauges, clock (has it stopped?) and interior lamps Wink
On a 2.2 it is Fuse 29.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753249 23rd Jan 2019 12:45am
paulas
ok thanks Martin I will try that. Yes the clock stopped.
Post #753427 23rd Jan 2019 6:59pm
paulas
however, I went out today and the clock started again on 3 occasions then stopped after 10 mins Question loose or burnt wire??? radio and interior lights still don't work though. All because I tried to replace interior light bulbs with LED ones, should have left well alone Sad
Post #753430 23rd Jan 2019 7:08pm
Martin
Site Admin
Remove the fuse as above, check the terminals in the fuse box for damage.
Replace the fuse with a new one to be certain it is OK.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753450 23rd Jan 2019 8:32pm
paulas
ok so finally sorted, thanks Martin and dorsetsmith. You were correct fuse 30 was the culprit and also another fuse, however, the reason I thought the fuse hadn't blown was because the fuse diagram in the owners manual is different to the fuse diagram on the inside of the fusebox cover!!! I was looking at the manual.
Post #754082 26th Jan 2019 4:29pm
Page 2 of 2 <12
