Home > Maintenance & Modifications > Radius arms refitting
Page 1 of 3 123>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi all
I replaced the bushes in the radius arms today (well one side anyway) , actually a much easier job than I anticipated !
However can I get the radius arms back on ? Can I hell!
Any tips much appreciated as I can’t Line up the pivet bolts with the holes . I have one side jacked up with axle stand under chassis and jack under axle to bear the weight .
Do I need to also jack the other side so the axle is floating ?
Thanks in advance
Post #750749 12th Jan 2019 5:41pm
Retroanaconda
Without the arms fitted the axle will rotate. Try sticking the jack under the diff nose to rotate it forwards and see if that lines them back up again.
Post #750755 12th Jan 2019 6:00pm
Bluericky
Thank you retroanaconda
I’ve tried that and although I can get a pivot bolt hole on one side to line up I can’t get the bolt all the way through , it’s way off on the other side .
I’m thinking that maybe both wheels need to come off ? My only reservation then is that the axle will be hanging even lower and even further round .
I did it a few years ago on an old defender and they slapped straight back on so not sure what I’m doing wrong this time
Post #750757 12th Jan 2019 6:10pm
jst
The axle has just rotated about its diameter and the other side has moved slightly. I always do it with chassis on axle stands, trolley Jack under diff nose, both wheels off, large pry bar, lump hammer and parallel punch to line holes. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #750765 12th Jan 2019 6:51pm
Bluericky
Thank you JST , I think I’ll take the other wheel off as to your suggestion
Post #750773 12th Jan 2019 7:11pm
roel
I allways the weels on and just put a jack under the front bumpe to take some weight. It still rests on the springs. That way everything is lined up as normal. If needed I use a steel bar to force it a little to get it lined up. Roel
2003 90 Td5 (2009-now)
Post #751003 13th Jan 2019 6:18pm
excossack
Ive just ordered the bushes for my radius arms, so this topic is of interest 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #751102 13th Jan 2019 9:29pm
Bluericky
Thanks all I managed to get them both done this morning. I thought the bush removal and replacement was going to be the hard part but that was relatively straightforward!
I ended up placing a small bottle jack from the outrigger to the axle in order to push the axle far enough away to get the pivot bolts in . Also a trolley jack underneath to push the radius arm into its brackets . I will confess that I also used a hammer to tap them all through without any ill effects !
The second arm took relatively no time , number one was a learning curve . Replaced track rod and ball joints with HD greaseable whilst I had it all apart. All made a huge difference, still pulling to the left like a Censored though !
Post #751331 14th Jan 2019 10:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Are your tyre pressures ok? Brakes binding? Are all the ball joints correctly aligned? If the tracking is out she will pull. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #751339 14th Jan 2019 10:52pm
Bluericky
Hi Mash
I’m slowly eliminating everything . Tracking has been checked twice and is apparently spot on, air pressure is good , changed brake pads and one seized calliper , swivel preload is good , bearings seem fine
It has had a new to me axle and steering box fitted relatively recently so I’m suspecting one of those to be at fault to be honest . Should the power steering box be centralised in some way before the drop arm is fitted ?
There’s a ton of backlash in the front diff so I’m going to swap that over as I have a spare
Post #751344 14th Jan 2019 11:17pm
Mash
The steering box should be centralised prior to the drop arm being fitted, have seen people fail to do this and it results in different turns left and right, also seen the wrong drop arm fitted ie a l/h one on a r/h/d wagon, that gives interesting faults.
Assume the tracking was done post all other work.
Other things could be a bent tie rod, or as another thread on here suggested some after market steering dampers can cause this.
Does it pull under acceleration, normal driving or braking or all 3? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #751346 14th Jan 2019 11:27pm
Bluericky
It’s more of a constant pull to the left , it doesn’t feel like anything’s jamming . It is worth noting that the ride feels more choppy on the left than the right , pot holes etc feel harsher. It’s also stiffer to steer under acceleration.
I have Bilstein B6 shocks fitted with standard Bearmach springs front and back but they were there before the problem .
Alignment was done after axle swap but was spot on !
My gut tells me it’s the steering box or the differential both irritatingly large jobs
Post #751364 15th Jan 2019 7:28am
yostumpy
Swap front tyres over, left to right, see if it pulls them, if so which way! 'Volvo XC 70, taking the rough with the smooth’
Post #751366 15th Jan 2019 7:58am
Bluericky
I haven’t tried, that as to be honest I cant see why that would suddenly be a cause of pulling left , unless they were under inflated ! But I will otherwise I’ll look like an utter muppet if that is the cause , having changed axles and steering boxes !!
I have had a thought ...
When the axle was replaced by our local 'Land rover Specialist' the steering was atrocious , floaty and unpredictable . I had a look underneath and noticed that the left front spring wasn't located in the top mount , it was half in half out and as a result shaped like a banana . I popped it back in and haven't thought about it again . It was like this for maybe 3-4 days , could this have warped the spring causing this pulling to the left or is that highly unlikely ?
Post #751367 15th Jan 2019 8:12am
Bluericky
I swapped the front wheels over today and it’s now pulling even more to the left along with steering wheel also being off centre (also to the left ) !
I’ll be swapping them back !
Post #751427 15th Jan 2019 12:27pm
Page 1 of 3 123>
