Home > Maintenance & Modifications > Radius arms refitting
Page 2 of 3 <123>
hank
What steering damper do you have fitted? There is an itnteresting thread and video here https://www.defender2.net/forum/topic65474.html
Could be worth considering > 110 XS Double Cab
Post #751434 15th Jan 2019 2:10pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I have an Armstrong OEM damper fitted , I’ll check out the video
Post #751437 15th Jan 2019 2:14pm
hank
Probably not applicable to you then aside than for interest! > 110 XS Double Cab
Post #751438 15th Jan 2019 2:29pm
Bluericky
Just watched it and really interesting, makes total sense .
I had a terrafirma RTC damper fitted to a 300tdi years ago. It seemed a good idea at the time but only masked the real problem!
Post #751443 15th Jan 2019 2:33pm
yostumpy
Why was the axle replaced in the first place? 'Volvo XC 70, taking the rough with the smooth’
Post #751834 17th Jan 2019 9:39am
landy andy
Post #751838 17th Jan 2019 9:58am
landy andy
You mention it’s worse whilst applying drive. Have you tried driving it with front prop removed?
I would also add, Ive never had tracking done that was spot on, and I’ve never driven a Defender that just straight lined like a modern vehicle.
Post #751839 17th Jan 2019 10:03am
Bluericky
Hi Landy Andy
I’ve not tried with the prop shaft removed but if I take it out of gear down a long hill it still pulls left so I imagine that’s the same thing
I’m going to take the steering shaft off today to have a look at the UJ’s and re centralise the Power steering box while I’m at it as I read somewhere that an uncentralised box will make the steering vague and pull
Post #751844 17th Jan 2019 10:36am
Bluericky
Another thing , I was looking at the workshop Manual for a puma last night and the recommded front springs for RHD DC are yellow/yellow both sides NRC 8045
When I ordered springs from Paddocks a few months ago , I was given one NRC 8044 and one NRC 8045 but this is the LR recommendation for LHD !
Is that going to make any difference ? I imagine not really
Post #751847 17th Jan 2019 10:54am
landy andy
Have you checked from Center, how many turns to the right and how many turns to the left?
Can’t remember but I thought drop arm went on in correct place or very wrong place due to the splines.
Once the drop arm is in the correct place, you can centralise the steering use a hole in the steering box, and the two prongs on the drop arm by aligning them with pin/drill bit/locating dowl
Post #751851 17th Jan 2019 10:58am
landy andy
Post #751855 17th Jan 2019 11:04am
landy andy
I must admit that I’m always puzzled by different springs on different sides.
So should you change springs when you go on holiday, or if you’ve got a fat girlfriend? Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
But yes it could make a difference for you.
Post #751857 17th Jan 2019 11:06am
Bluericky
It does seem a bit daft having different springs !
I rarely have a full fuel tank and the Mrs isn’t a feather
Post #751862 17th Jan 2019 11:35am
yostumpy
Is it possible that your replacement axle, if not new, is either bent or been repaired? 'Volvo XC 70, taking the rough with the smooth’
Post #751866 17th Jan 2019 11:50am
Bluericky
Possibly but it was doing it before the new axle so fingers crossed . I think it started to show when the pump was replaced and the suspension was changed ,
Tip never do too many jobs at once , it makes fault diagnosis harder !!!
Post #751868 17th Jan 2019 11:52am
Page 2 of 3 <123>
