Home > In Car Electronics > Repurposing Rear Washer Pump Connection for Winch Isolator
Page 2 of 2 <12
hank
Update on this...
It worked! The heated rear screen switch plugged in to the blue rear screen wash plug powers up the winch solenoid via a patch lead from the rear wash pump econoseal connector to the solenoid in the near side battery/seat box.
One issue though... the switch does not illuminate when I turn lights on? The orange light illuminates to show that the switch is active but goes out when the vehicle lights are on. Any thoughts?
Post #748861 3rd Jan 2019 10:28am
PaulMc
The rear washer switch's illumination is wired 'backwards' compared to most of the other switches.
Both switches switch a live from pin 1 to pin 4
The HRW switch's illumination has its live on pin 2, with its earth on pin 5
The rear washer switch's illumination has its live on pin 5, with its earth on pin 2
You could swap the wires between pin 2 and pin 5 in the rear washer switch's connector.
Or, you could split the HRW and rear washer switches, and use the bottom half of the rear washer switch, with the latching top half of the HRW switch.
. Paul.
Post #748897 3rd Jan 2019 2:43pm
hank
Bow down switch guru. Will give the second option a try!
Post #749268 4th Jan 2019 10:46pm
hank
Any idea whether the freelander rear wash switch is wired the same? These are more readily available
www.ebay.co.uk/itm/172667057737 > 110 XS Double Cab
Post #749764 7th Jan 2019 4:25pm
PaulMc
Yes, the Freelander-1 rear wash/wipe switch is wired the same as the Defender switch -
Live switched from pin-1 to pin-4
Illumination in on pin-5, earth on pin-2
However, it uses the Black 5-way connector, rather than the Blue one.
. Paul.
Post #749779 7th Jan 2019 6:25pm
hank
That’s that option out of the window then. Will get a Defender one > 110 XS Double Cab
Post #749787 7th Jan 2019 7:11pm
Martin
Site Admin
Mod the connector to fit?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #749807 7th Jan 2019 8:36pm
hank
Does it just need the plastic ‘key’ strip trimming? > 110 XS Double Cab
Post #749808 7th Jan 2019 8:37pm
hank
Paul you beauty
 > 110 XS Double Cab
Post #770052 25th Apr 2019 6:08pm
Page 2 of 2 <12
