Home > In Car Electronics > Repurposing Rear Washer Pump Connection for Winch Isolator
hank
Hello
I am looking for wiring diagrams for the rear washer jet pump if anybody can steer me in the right direction? 2007 Defender Puma if it makes any difference
Thanks
edit: see below!
Post #729763 18th Sep 2018 2:42pm
hank
Perhaps you auto electric wizards can evaluate my idea...
I have a 110 double cab so no rear washer, switch or pump however the rear wash wiring should be present behind the dash blanking switch
If I mount my winch switch (https://www.mudstuff.co.uk/genuine-style-tdci-td5-switch-winch.html) in the centre console, plugged up to the redundant rear washer connector in the dashboard then activating the winch switch should make live the rear washer pump connector in the engine bay. I can then take this live feed and extend it as the exciter for my winch isolator solenoid, back to earth.
The idea behind this is that I don't have to disturb the factory wiring.
Any thoughts on why this wouldn't work?
Post #729768 18th Sep 2018 3:03pm
It should work fine. I used the RWW switch for my headlamp washers.
On an '07 all the wiring is present and if you choose the right switch (ie a latching one rather than non latching) then you will switch on the spare connector adjacent to the screenwasher pump. This is quite capable of switching a relay (my super heavy duty pumps are both relayed now).
Post #729774 18th Sep 2018 3:43pm
sako243
Only thing is don't you want a two way circuit? Winch in and winch out? I'd hazard a guess it's only one way for the washer pump. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #729820 18th Sep 2018 8:42pm
Jimmy B
Is this just to control an isolator or the in/out solenoids?
Post #729824 18th Sep 2018 9:00pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
It's for the isolator solenoid sako so he just needs a make and break circuit to operate it on and off. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #729826 18th Sep 2018 9:02pm
sako243
Fair point, missed the title Embarassed Ed
Post #729834 18th Sep 2018 9:26pm
PaulMc
The Mudstuff switches are based on the auxiliary lights switch, which is an earth-switching switch, using the black 5-way connector.
This isn't compatible with your Defender's rear washer wiring for two reasons -
1. The rear washer switch switches an ignition switched live from pin 1 to pin 4.
The Mudstuff switch switches a relay's coil to earth from pin 1 to earth on pin 4.
2. The Mudstuff switch uses a black 5-way connector. Your Defender's rear washer wiring will have a blue 5-way connector on it.
There are a couple of ways around this -
1. Use a heated rear screen switch body, with your Mudstuff switch front on it.
The heated rear screen switch is wired the same as the rear washer switch, it latches, and it uses the blue connector.
2. Swap the blue connector on your Defender's wiring for the black one that comes with the Mudstuff switch, and modify the switch's internal layout to turn it into a live-switching switch.
The blue connector's terminals are easily released, in order insert them into the black connector.
The internal modifications to the switch are a small cut in the brass track to separate pin 3 from pin 4, and a link from pin 4's track to pin 5's track, to enable the tell-tale LED. This can also be achieved by adding an external loop of cable from pin 4 to pin 5.
. Paul.
Post #729855 19th Sep 2018 2:07am
hank
Fantastic knowledge as per usual gents thank you Bow down
Paul's suggestion "Use a heated rear screen switch body, with your Mudstuff switch front on it" is sounding like the most straightforward solution at the moment. I will get some bits ordered and report back
As clarified, this is just for the winch isolator switch. Winch control will be by the hand held remote
Thanks once again, this has saved me much head scratching!!
Post #729858 19th Sep 2018 6:01am
hank
Paul Mc - just to clarify; "the heated rear screen switch uses the blue connector" ... only the loom connector is blue right? The switch body itself is black? (I am on ebay and the switch is black)
Post #729859 19th Sep 2018 6:05am
^^^ Correct, only the connector is blue.
Post #729864 19th Sep 2018 7:41am
hank
Thumbs Up ordered, will report back
Post #729872 19th Sep 2018 8:59am
hank
Can anyone help me out with the name/type of plug/connector used for the rear washer pump? So I can make up a patch lead for my isolator solenoid
Post #734051 10th Oct 2018 4:31pm
IIRC it is a standard 2-pin Econoseal connector of the female gender.
Post #734066 10th Oct 2018 6:26pm
hank
That’s it! I knew it had the word seal in it!
Thanks a lot
Post #734080 10th Oct 2018 7:31pm
