![]() | Home > In Car Electronics > Repurposing Rear Washer Pump Connection for Winch Isolator |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
The rear washer switch's illumination is wired 'backwards' compared to most of the other switches.
Both switches switch a live from pin 1 to pin 4 The HRW switch's illumination has its live on pin 2, with its earth on pin 5 The rear washer switch's illumination has its live on pin 5, with its earth on pin 2 You could swap the wires between pin 2 and pin 5 in the rear washer switch's connector. Or, you could split the HRW and rear washer switches, and use the bottom half of the rear washer switch, with the latching top half of the HRW switch. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
Any idea whether the freelander rear wash switch is wired the same? These are more readily available
www.ebay.co.uk/itm/172667057737 > 110 XS Double Cab |
Yes, the Freelander-1 rear wash/wipe switch is wired the same as the Defender switch -
Live switched from pin-1 to pin-4 Illumination in on pin-5, earth on pin-2 However, it uses the Black 5-way connector, rather than the Blue one. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
That’s that option out of the window then. Will get a Defender one > 110 XS Double Cab
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Mod the connector to fit?
Does it just need the plastic ‘key’ strip trimming? > 110 XS Double Cab
Paul you beauty ![]() Click image to enlarge > 110 XS Double Cab |
