Home > Maintenance & Modifications > TD5 rev counter - the cheap option
Page 3 of 4 <1234>
Gilloverland
Number of cylinders has nothing to do with a rev counter that takes a feed from the alternator.
Some rev counters for petrol engines take a pulse from the ignition and so are switchable for 4 or 8 cylinders.
Post #749293 4th Jan 2019 11:49pm
Gilloverland
Post #749294 4th Jan 2019 11:49pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Re: TD5 rev counter - the cheap option
Jontd5 wrote:
Was looking to get a rev counter for my 110, bought a cheap universal diesel on on eBay for 20 quid and added a W terminal to back of alternator. Didn't even have to take alternator off, was able to take back cover plate off from underneath
Hi. I'm currently considering installing one in my 300Tdi, how would you describe the build quality of this product?
Post #749382 5th Jan 2019 3:47pm
Jontd5
Ireland
I'm happy with it - I bought it because it was sort of close in style to the original defender gauges,
Pros - cheap , looks ok, postage was reasonably quick, it came with instructions. It works fine with no issues, seems of half decent quality
Cons - it was made in china so for 20 quid - so if it fails in a few years I'll just swap it for the same again. - 5 minute job
Post #749511 6th Jan 2019 6:15am
jfh
Thanks for the feedback.
Post #749512 6th Jan 2019 6:46am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
To bring up an oldish thread...
I’ve used the same gauge as you ... ordered it when I saw this thread ages ago. Finally got round to acting on it
Wired it all in, took alt off to add the terminal, definitely the one you circled.
Standard same looking TD5 alt as you
When I turn ignition on it powers up. Flicks right to left. Then just sits and 0 and does nothing. No amount of twiddling with the dial on the back does anything. Illumination functions correctly when I go for the lights so I’m certain it’s wired correct.
I gave up and went in for lunch and cider!
I might go back out and multimeter the dash feed I took for W, I’m assuming it should read 12v but may be erratic due to pulsing? Insta: @thebenjordan4x4
Post #824407 10th Apr 2020 2:19pm
benniferj
Right, I got this.
Metered it and sweet nothing.
Had a head scratch and then realised I had totally missed plugging the multi plug into the back of the alt!!! Weird, no 'alt dead' illumination on the dash!?
Had a fiddle about and just about managed to get a hand to the plug, and magically of course it worked... 6000rpm at idle.
Got the Nanocom out and metered it and twiddled the dial on the back, and yes totally accurate now and sorted, £20 and a bit of time.
Post #824424 10th Apr 2020 3:33pm
sako243
You're unlikely to get an alternator dead signal because with the plug un-plugged there's no path to ground to activate the light. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #824437 10th Apr 2020 5:21pm
miker
As I have some spare time, and the truck is on axle stands amid some fairly major works, I ordered one at last! It'll probably arrive just in time for me to go back to working 8 days a week...
Post #824448 10th Apr 2020 5:47pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
benniferj wrote:
Right, I got this.
Fantastic! Well done you! Looks good. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #824570 11th Apr 2020 10:42am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Bit of a thread revival, but I've just done this job on my td5 and it's working perfectly, so thanks for everyone's contributions!
It's definitely possible to do it while the alternator is still on the car, but it is extremely awkward! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #864769 1st Nov 2020 3:29pm
Hazza
Just fired up the 110 for the first time in a week, battery light stayed on, rev counter at 0, and alternator smoking hot...
I did clean the alternator down with brake cleaner before I started the rev counter job last week as it was really oily. It worked fine on the drive afterwards, but seems it is now dead. Looks like I've killed the alternator - little warning for anyone doing this job to not be too liberal with the brake cleaner when doing this job! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #866080 8th Nov 2020 2:46pm
starter
Thanks hazza for the warning, i received mine and will try to fit soon.
Post #866624 10th Nov 2020 11:18pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Ta. Ive still got mine tondo. But its on the list of one day jobs..... 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #866637 11th Nov 2020 6:13am
miker
I finally managed to get mine done a few weeks back, needed a but of calibrating against my nanocom, but works great!
Makes the other dials look a bit dingy by comparison though...
Post #951966 8th May 2022 5:38pm
Page 3 of 4 <1234>
