Home > Maintenance & Modifications > TD5 rev counter - the cheap option
Page 4 of 4 <1234
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Only 2 years late...
It wasn't the brake cleaner that killed my alternator. I (foolishly) nipped the wire I ran to the rev counter under the alternator's cover when putting it together. The insulation failed and the short killed the alternator.
Replacement alternator in place, correctly routed wiring, and the rev counter works perfectly. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #952697 16th May 2022 2:17pm
Davy
Ireland
I know it’s an old post but can anyone tell me if the (W) terminal is permanently live I’ve a parasitic draw I’m searching for.
Post #997789 27th Jun 2023 7:45pm
Mountain_man
Wales
I think it may be permanent live. I am currently doing a hybrid built, repurposing my old Disco trayback into a "defender" ute for farm use. I have to build my own wiring loom so have been checking and labling all wires. The alternator wiring on the engine is as it was on the Disco so is wired for tacho. When checking the 3 wire outlets I did find the one which was for the tacho to be a permanent live.
Post #997808 27th Jun 2023 9:34pm
rallysteve
W terminal shouldnt produce a voltage when the engine is not running. It outputs a raw a.c. voltage proportional to engine speed with a rms voltage of 6-8v
Post #997824 28th Jun 2023 7:15am
NickMc
Anyone got a new link to this rev counter?
Post #997876 28th Jun 2023 2:22pm
Davy
Ireland
Thanks for the replies so I’ve had it checked out and NO It’s not live until the ignition is turned on.
Post #997914 28th Jun 2023 8:25pm
johnnyeebaby
 2002 Defender 90 Td5 CSW Barolo Black
Hi ,
Just wondering what Ignition live wire is everyone using on the Instrument. For the Rev clock. Thanks
Post #1032733 24th Apr 2024 8:58pm
johnnyeebaby
Looking for help with this please.
Ive fitted One and not having much luck getting it to read.
Ive connected the Green to the Alt Terminal, Done with out removing the Alternator.
Ive connected the Red to the Ign Live of the Temp Gauge
Ive Connected the Earth the the Earth on the dash bulb
Ive connected the Yellow to the Live of the Dash Bulb.
When i Start the Engine, The Needle on the gauge sweeps, But sits back at zero.
All the Dash Lights very faintly light up
When i switch on the Lights all the lights and rev gauge comes on.
When i switch off and on the lights with Ign on the gauge will sweep.
Ive also fitted all Led light bulbs to my Cluster while it was out not sure if this would cause a problem.
Looking for Suggestions please
Post #1035760 26th May 2024 7:59pm
Page 4 of 4 <1234
