Home > Maintenance & Modifications > TD5 rev counter - the cheap option
Page 2 of 4 <1234>
DunningBoy
I'd love to see the pictures of this to see if it is something I can attempt.
Post #747712 28th Dec 2018 12:50pm
Jontd5
Ireland
That's photos of my spare alternator - basically remove the wires and back cover and cut away the piece of cover circled in red there's and fix a wire to the screw that's right underneath it.
Post #747713 28th Dec 2018 12:56pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Mine arrived today from Taiwan 10 days after ordering.
Is it a straight plug and play or is some calibration required? 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #747732 28th Dec 2018 2:11pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Thank you for the pics.
How does attaching a wire to the screw give the revs?? Or am I missing a point??
I think I was told before by someone that the revometer has to be wired into the ECU on the TD5 Defender......???? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747736 28th Dec 2018 2:22pm
MJN110
Does this make sense Adam? 2016 Defender Landmark 90
Post #747738 28th Dec 2018 2:38pm
Adam17
Thank you bud, kinda clears things up.
Appreciate your time Wink Regards
Adam
Loving The Duchess
Post #747740 28th Dec 2018 2:53pm
MJN110
Its a pleasure I have just been reading your Defender story it is a great read.
I note you are a detectorist like myself and use a CTX and a 17 coil like i do.
Recently purchased a pro 45 harness well worth buying if you dont have one. 2016 Defender Landmark 90
Post #747749 28th Dec 2018 4:15pm
Jontd5
Ireland
Attaching a wire to that screw on the back of the alternator is basically the same thing as using the W terminal on a 200/300tdi alternator - it's connected to one off the stator windings before the rectifier.
As far as calibration goes there's a calibration screw on the rear of the rev counter - the smallest of turns moves needle a lot. Ideally a nanocom on live data is best to calibrate it but both my td5s idle at 780 -800 rpm so setting your idle to that will get it as close as you really need
Post #747785 28th Dec 2018 6:44pm
Adam17
Well thank you chap! Indeed, I have been detecting for a little while now, a great hobby, love the outdoors, and love the CTX.
Ill pm you the rest of this reply... Its turning into a huge spiel lolol Regards
Adam
Loving The Duchess
Post #747885 29th Dec 2018 10:51am
Adam17
Cheers Jontd5. Ill give it a go when I get some spare funds. Regards
Adam
Loving The Duchess
Post #747887 29th Dec 2018 11:04am
Gilloverland
Has anyone found a way to tint the back-light green?
Post #747962 29th Dec 2018 7:10pm
Jontd5
Ireland
Open up the gauge and use a green marker on leds and back on dial
Post #747964 29th Dec 2018 7:19pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
Many thanks to Jontd5 for telling us about this tacho Thumbs Up
Fitted mine a few days ago, and it works brilliantly, best £18 i've spent!
I've no idea, how you manged to fit the alternator wire from below though - I quickly got fed up with crud falling into my eyes, and decided to take the alternator out from above Very Happy
I couldn't get the back off the tacho to colour the LEDs (didn't want to break it), so I've left as is for now Very Happy '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #749145 4th Jan 2019 12:25pm
Jontd5
Ireland
👍👍 good to hear it worked out for you. Yeah the alternator is a pain of a job, was a good hour underneath mine. The black ring around the glass will come off - widen it out from the back, the defender dash will hide any marks in the paint. The needle will pull off and dial will come out, gotta line up needle at zero when putting it back together
Post #749152 4th Jan 2019 12:43pm
sako243
miker wrote:
Very interesting! I've always been under the impression that even adding a W terminal wouldn't work due to the 5 cylinder vs 4 cylinder thing. Have you "calibrated" it against a nanocom or similar?
Any details on the mod to add the terminal?
Why would it make any difference as to the number of cylinders?
The W terminal is basically one of the poles from the alternator, that's going to spin at a fixed ratio of the crank (depending on pulley speed and number of poles in the alternator). If you have 4, 5, 8, 12, 16, 24 cylinders it doesn't matter because the crank still turns at the same speed. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #749191 4th Jan 2019 4:20pm
Page 2 of 4 <1234>
