Home > Td5 > Oil on clutch pedal TD5
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Just noticed a small oily patch on my rubber mat under the clutch pedal and some oily residue on the clutch pedal. Anyone any ideas.....is it serious.........whats the fix
thanks Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #74321 5th Jun 2011 4:20pm
Lorryman100
Sounds like the seal has given up on the master cylinder and needs replacing. You can get an overhaul kit comprising of a new O ring and seal. Not a hard job to do, just clean the cylinder and remove any burring before putting in new O ring Thumbs Up
Post #74322 5th Jun 2011 4:38pm
alanhid
yep that what I thought..........haynes manual for bedtime reading tonight Rolling Eyes Life is not a rehearsal!
Post #74354 5th Jun 2011 7:32pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I was in there on Saturday, you need a mate to hold the clutch pedal down while you undo nut 3 on the drawing. You will need a ratchet spanner to get that off.
The lid should have a gasket, this must be to keep water out of the car, its expensive too ( �18 ) i just used some silicon seal.
Not a bad job really, just fiddley. May pay to remove the bonnet.
Post #74397 6th Jun 2011 6:48am
alanhid
Paul,did you replace the cylinder or go for the repair kit? Im thinking of just replacing the cylinder. Life is not a rehearsal!
Post #74402 6th Jun 2011 7:08am
Paul_1978
I was in there to change the pedal spring.
But looks ok to take part, all obvious and fairly easy to get to.
Post #74407 6th Jun 2011 7:46am
Steve in Germany
Wales 2000 Defender 90 Td5 CSW Alveston Red
Is the kit available from LR dealer or aftermarket....Needs doing on my 90
Post #74666 7th Jun 2011 3:43pm
Lorryman100
Post #74682 7th Jun 2011 5:33pm
Steve in Germany
Cheers Thumbs Up
Post #74815 8th Jun 2011 1:01pm
alanhid
Job done Thumbs Up Wasn't that hard, more awkward than technical. Took the bonnet off for easier access. Chuffed with myself Cool Life is not a rehearsal!
Post #75826 14th Jun 2011 5:33pm
Steve in Germany
How long did it take you
Post #75828 14th Jun 2011 5:35pm
alanhid
About 3hrs. Took a while to get the pedal box out- awkward. Took a while to bleed and adjust the clutch, other than that pretty straightforward. Tip of the day - remove the bonnet for access. Life is not a rehearsal!
Post #75891 14th Jun 2011 8:32pm
gambit
Have you done the slave too? Some advice is to do both as they wear out at the same rate
Post #77435 23rd Jun 2011 7:42pm
