![]() | Home > Td5 > Oil on clutch pedal TD5 |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Sounds like the seal has given up on the master cylinder and needs replacing. You can get an overhaul kit comprising of a new O ring and seal. Not a hard job to do, just clean the cylinder and remove any burring before putting in new O ring
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
yep that what I thought..........haynes manual for bedtime reading tonight
![]() Def 90td5 CSW xs 2006 |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
I was in there on Saturday, you need a mate to hold the clutch pedal down while you undo nut 3 on the drawing. You will need a ratchet spanner to get that off.
The lid should have a gasket, this must be to keep water out of the car, its expensive too ( £18 ) i just used some silicon seal. Not a bad job really, just fiddley. May pay to remove the bonnet. |
Paul,did you replace the cylinder or go for the repair kit? Im thinking of just replacing the cylinder. Life is not a rehearsal!
I was in there to change the pedal spring.
But looks ok to take part, all obvious and fairly easy to get to. |
Steve in Germany Member Since: 18 Mar 2011 Location: Up a hill in Brecon Posts: 54 ![]() ![]() ![]() |
Is the kit available from LR dealer or aftermarket....Needs doing on my 90
Repair kit:
http://www.paddockspares.com/pp/DEFENDER/C...50732.html or new master cylinder: http://www.paddockspares.com/pp/DEFENDER/C...Lucas.html |
Job done
![]() ![]() Def 90td5 CSW xs 2006 |
How long did it take you
About 3hrs. Took a while to get the pedal box out- awkward. Took a while to bleed and adjust the clutch, other than that pretty straightforward. Tip of the day - remove the bonnet for access. Life is not a rehearsal!
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 ![]() |
Have you done the slave too? Some advice is to do both as they wear out at the same rate
