![]() | Home > Maintenance & Modifications > TD5 rev counter - the cheap option |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Very interesting! I've always been under the impression that even adding a W terminal wouldn't work due to the 5 cylinder vs 4 cylinder thing. Have you "calibrated" it against a nanocom or similar?
Any details on the mod to add the terminal? |
Jontd5 Member Since: 09 Dec 2018 Location: Laois Posts: 39 ![]() ![]() |
Yeah wasn't sure it would work either - but set it up with nanocom at idle and at 1000, 2000, 3000 and 4000 rpm it was reading accurate. I bought the cheapest gauge I found for a diesel on eBay , partly because I wasn't sure it would work and partly it was reasonably simple in looks. It has no jumpers on the rear just a calibration screw. All I did with alternator was disconnect wire and remove the rear cover - managed to do it with alternator still in place, there a series of screws holding the rectifier plate onto alternator when you remove back cover one of these screws will be facing straight down towards the floor, i just attached a cable to that and ran it up to back of instruments, connected it up and all done.
It is a fiddle getting rear cover off but better than pulling alternator out. I will upload a photo of where to attach wire if that helps |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6170 ![]() ![]() ![]() |
nice job. Yes some pictures would be good.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Doesnt matter how many cylinders the engine has, the alternator still spins at the same speed. The only variable is the ratio of the crank and alternator pulley size 02' 110 TD5 Double Cab Rebuild Thread
These are photos from my spare alternator. I took off the rear cover and fitted a wire to the screw coming off the end of the stator
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Fantastic news! No more £200 rev counters!
eBay Item No. 362310571942
That's the gauge I used Last edited by Jontd5 on 19th Dec 2018 8:46am. Edited 2 times in total |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
Well done that man!!!! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
What make of alternator is it? 1999 Defender TD5 110
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
I love doing mods on my TD5 defender I have ordered the same rev counter and looking forward to fitting it.
Thanks for posting this info. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
That rev counter looks right at home in there
Standard Td5 alternator - denso I think |
https://photos.app.goo.gl/tPbTg3LXnboK8Fof7
Hopefully that video link will work |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Looking forward to seeing the pics - may have to give this a go myself ![]() That video is great. matches up perfect. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
