Home > Tdi > 200Tdi Starting Procedure |
Turn the key to position 1 and listen for the click of the glow plug relay switching off before starting. Darren
11th Dec 2018 9:34am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 168 |
I just jump in and turn the key, no matter how cold it is I've never needed to wait fires straight away
Mine very often sits for weeks without being started it has to be said |
11th Dec 2018 9:41am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2265 |
Like Mr Anorak, I wait until I hear the relay click off.
11th Dec 2018 10:38am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2672 |
Technically you should start it when the glow plug light goes out, not when the relay clicks. It is designed to apply some post-start heating which is why the light goes out before the relay clicks.
However I would bet that the OP’s issue is not related to the glow plugs, more likely the fuel draining back from the injectors when left for a period. Check the leak-off lines, these are prone to either loosening off or the pipe degrading, both of which will cause air to get in and result in poor starting after being sat for a while. |
11th Dec 2018 10:43am |
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 746 |
Leak off lines, interesting.
Where are these, and what do they look like? I thought it was fuel related. Many thanks 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
11th Dec 2018 11:20am |
My old 200tdi didn't have a glow plug light. I assumed they were all the same but mine's the only one of that particular model that I've driven. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Dec 2018 11:59am |
c18rch Member Since: 28 Nov 2012 Location: Sheffield Posts: 28 |
Likewise. Mine did 1500 miles last year. It has never not started on the first turn of the key. I never wait for the glow plug, just straight to start. 1988 110 200TDi Hard Top |
11th Dec 2018 12:21pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8143 |
How old is the battery and is it perm on a trickle charge ? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Dec 2018 1:07pm |
The leak off lines are the small diameter fuel pipes that run from each injector back down to the fuel injection pump. Not the metal hard lines but the rubber/plastic ones.
11th Dec 2018 1:38pm |
Great - thanks. 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
11th Dec 2018 2:54pm |
New and yes. Thanks 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
11th Dec 2018 3:16pm |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 |
How does your 200 suffer from poor starting, you dont say, eg is it excessive cranking, misfiring initially on start up, lots of white smoke on startup? Colder weather does have an impact.
Was the timing belt changed recently when the engine was out? As well as trying the other suggestions it might be worth getting the injector pump static timing checked properly by someone who knows about Land Rovers, this needs to be set correctly with a micrometer dial guage. |
11th Dec 2018 6:39pm |
Good point OJ
It cranks for sometime with no fiiring, does that twice and then on the 3rd go it fires a bit then starts and runs nicely and restarts with ease . No white smoke at all, bit of black when it finally gets going. Long story but timming belt was replaced short time before the rebuild started, so apart from a good clean, the engine was left well alone. Before reinstallation it had been left idle for 13 months, it fired straight into life with no bleeding or any tinkering, we just connected it all back up and bang it started. But that was in the summer. Thanks for all your input fellas. HK07 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
12th Dec 2018 8:53am |
Gilloverland Member Since: 12 Nov 2017 Location: Yorkshire Posts: 61 |
Thats air in the fuel
12th Dec 2018 6:57pm |
