Home > Tdi > 200Tdi Starting Procedure
Page 2 of 2 <12
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
HK07 wrote:
Good point OJ
It cranks for sometime with no fiiring, does that twice and then on the 3rd go it fires a bit then starts and runs nicely and restarts with ease .
No white smoke at all, bit of black when it finally gets going.
Long story but timming belt was replaced short time before the rebuild started, so apart from a good clean, the engine was left well alone. Before reinstallation it had been left idle for 13 months, it fired straight into life with no bleeding or any tinkering, we just connected it all back up and bang it started. But that was in the summer.
Thanks for all your input fellas.
HK07
Certainly sounds like air, have you noticed any recent fuel leaks, start by a check of all the fuel lines right back to the tank, lift pump, fuel filter, and as suggested the injector leak off pipes, when was the fuel filter last changed? Fuel pump?
if it was starting ok before it’s more likely something that’s happened since / when the engine was refitted,
Logically do one thing at a time and try it so you can keep track of what your finding,
Good luck Thumbs Up
Post #745344 12th Dec 2018 7:54pm
Procta
From my experience, a good quality heavy duty battery and really good set of glow plugs do the trick on start up. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #745539 13th Dec 2018 4:50pm
Mo Murphy
... not if there's no fuel.
50 Shades of Pennine Grey
Post #745589 13th Dec 2018 7:26pm
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Try parking it facing downhill and see if that improves it. I am told lift pump seals can leak.
Post #746737 21st Dec 2018 12:29pm
discoed
My 200 Tdi leaps into life as soon as the key is turned, whatever the temperature, my heater plugs aren't even wired up!
Post #749675 6th Jan 2019 11:10pm
Page 2 of 2 <12
