Home > My Defender > What Did You Do In Your Defender Today |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
So I spent my day, the morning at least, replacing the indicator stalk.
All is working good now. Click image to enlarge Click image to enlarge Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
4th Dec 2018 3:10pm |
Liam Member Since: 14 Nov 2016 Location: Rotterdam Posts: 32 |
Tested stage 1 tune in combination with the new gear box & transfer case from Ashcroft. Quite easily ran up to 90+ mph
7th Dec 2018 7:13pm |
Yulong Member Since: 18 Nov 2017 Location: Aberdeen Posts: 110 |
Given its pre-Xmas wash!
7th Dec 2018 8:58pm |
Soner Member Since: 12 Sep 2018 Location: Athens Posts: 38 |
Click image to enlarge Click image to enlarge Tachometer |
7th Dec 2018 10:59pm |
mermade Member Since: 08 Dec 2018 Location: cheshire Posts: 3 |
ordered some powerflex shock bushes to have a crack at fitting over winter!
https://powerflexstore.co.uk/land-rover/defender-2002-2016/ |
8th Dec 2018 10:28am |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1211 |
Another year - another tree
Click image to enlargetree by Richard Holmes, on Flickr 2010 XS USW 1957 Series One 88 diesel 1958 Series One 88 4x2 |
8th Dec 2018 1:18pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Room for a much bigger tree there. |
8th Dec 2018 3:51pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
I used mine as a mobile work platform to put the Christmas lights in a tree at my parents and then put their LED Tree on the porch.
Thank heavens for a fully decked Brownchurch rack 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
8th Dec 2018 5:16pm |
must try harder........................
Click image to enlarge0_CaptureJPG by Richard Holmes, on Flickr 2010 XS USW 1957 Series One 88 diesel 1958 Series One 88 4x2 |
8th Dec 2018 5:18pm |
He's going to need a lot of tinsel and lights to decorate that. |
8th Dec 2018 7:45pm |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 167 |
Finally completed this over the last few days and I’m really happy with it.
Somehow with the Puma Defender I just can’t see enough behind me for parking – must be some kind of optical illusion as it’s exactly the same dimensions as the 300Tdi and I had no problems there 🙂 Anyway, fairly straightforward to fit – The ‘Garmin BC™ 30 Wireless Backup Camera’ is powered by the reversing light with a small transmitter unit tucked away behind the rear left speaker. For the Head unit (Garmin Sat Nav) I dropped the power cable with inline receiver behind the dash. The cigarette lighter type plug also converts from 12V to 5V - so I’m using a 12V cigarette lighter socket with a flylead hooked up to a fuse tap. All tucked up by the fuse box so nicely out of sight. Not a bad setup and works really well – unit switches between Sat Nav and camera as soon as you stick it into reverse. No more crossing fingers and winging it when parking I also managed to pick up a used SVX type Garmin mount but I'm not sure I fancy drilling the 2 holes in the dash - maybe another day..... Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
9th Dec 2018 8:52am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
24Heuer, I have exactly the same system in mine and really pleased with it, good picture clarity too.
I also had the original SVX mount and tried it with this screen but the size and weight of the screen on the SVX mount meant it kept tipping forward if I went over and uneven road surface (living in Cornwall that’s every road surface ) And yes I did drill the two holes to try it. 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
9th Dec 2018 9:08am |
Ha! Sulisuli, good info - thanks.
I think I'll be sticking with the windscreen mount for now then It has totally changed my parking experience btw - parallel kerbside parking in the dark was easy last night! Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
9th Dec 2018 11:19am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3675 |
Wheel spacers for me this weekend. Only 30mm but makes a big difference.
Click image to enlarge |
9th Dec 2018 6:19pm |
