Home > Td5 > Td5 fuel pressure regulator - repair kit X8R
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Gents
Has anybody tried this repair kit from X8R which you can find on eBay ( they announce high quality components).....should I go this way , has anybody install it
 Happy Travel
www.thegippo.wordpress.com
Post #740174 12th Nov 2018 9:24pm
NickMc
I’ve tried these kits (not from that company) before on my own vehicle only to see if they worked and they didn’t last too long, think a lot depends on what part is leaking on yours and how good the body is (flat, ovaled out holes) the cleaner the better. Most of the time it’s the valve leaking.
Post #740194 12th Nov 2018 9:55pm
Rich1968
Bought a Bosch FPR from Opie oils then a set of seals from ebay - less than £30.
Rich
Post #740207 12th Nov 2018 10:31pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I’ve had that exact kit in my 2000 MY 10P motor for three years now with no issue at all. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #740213 12th Nov 2018 11:38pm
sherifsalem
Hi All
thank you for your input, the valve is the one leaking in mine and the valve here is a Boch supposedly a good brand.
Just heard from my mechanic that these valves sometimes are not regulated properly at 4 bar which is the pressure coming from the fuel pump and can create other problem
so fair enough that somebody tried it and it worked Happy Travel
Post #740304 13th Nov 2018 5:18pm
roel
I used X8R for my Disco 3 suspension air compressor. Good quality kit, so I won't have a problem using them for the td5 fuel pressure regulator. Roel
2003 90 Td5 (2009-now)
Post #740331 13th Nov 2018 6:51pm
landy andy
Ordered some parts from them Sunday, so pleased to hear the good stuff.
Post #740396 13th Nov 2018 9:18pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I'm afraid to say for me it didnt work. But mine was a Ebay not xk8
1st time out the seal I'd replaced failed. Luckily the kit had 2 seals so I did it again and it was fine. But then the diarprahm in the valve that came with the kit failed. Back on std lr one now 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #740443 14th Nov 2018 7:44am
sherifsalem
The repair kit did not work after doing all as far as i know correctly, seems like it is starting again to let some kind of oily mix out of the fitted valve (which is a boch)
the background is that i had the original on many years ago and then it failed and i fitted a new original one that again did not resist for a long time.( a couple of years) it was badly lately pouring out this oily mix
So i decided to keep the regulator and repair the valve which upon purging the system and starting the car, i noticed the next day a slight oily mist coming out from the valve
Do you have any ideas what could be wrong?
is it pressure? what should i be looking for ? what is causing the valve to leak or blow in such a short time?
thanx gents Happy Travel
Post #743055 29th Nov 2018 9:23pm
