![]() | Home > Td5 > Td5 fuel pressure regulator - repair kit X8R |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 ![]() ![]() ![]() |
Gents
Has anybody tried this repair kit from X8R which you can find on eBay ( they announce high quality components).....should I go this way , has anybody install it Happy Travel www.thegippo.wordpress.com |
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 84 ![]() ![]() |
Bought a Bosch FPR from Opie oils then a set of seals from ebay - less than £30.
Rich |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 967 ![]() ![]() ![]() |
I’ve had that exact kit in my 2000 MY 10P motor for three years now with no issue at all. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Hi All
thank you for your input, the valve is the one leaking in mine and the valve here is a Boch supposedly a good brand. Just heard from my mechanic that these valves sometimes are not regulated properly at 4 bar which is the pressure coming from the fuel pump and can create other problem so fair enough that somebody tried it and it worked Happy Travel www.thegippo.wordpress.com |
I used X8R for my Disco 3 suspension air compressor. Good quality kit, so I won't have a problem using them for the td5 fuel pressure regulator. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5852 ![]() ![]() |
Ordered some parts from them Sunday, so pleased to hear the good stuff.
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
I'm afraid to say for me it didnt work. But mine was a Ebay not xk8
1st time out the seal I'd replaced failed. Luckily the kit had 2 seals so I did it again and it was fine. But then the diarprahm in the valve that came with the kit failed. Back on std lr one now 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
The repair kit did not work after doing all as far as i know correctly, seems like it is starting again to let some kind of oily mix out of the fitted valve (which is a boch)
the background is that i had the original on many years ago and then it failed and i fitted a new original one that again did not resist for a long time.( a couple of years) it was badly lately pouring out this oily mix So i decided to keep the regulator and repair the valve which upon purging the system and starting the car, i noticed the next day a slight oily mist coming out from the valve Do you have any ideas what could be wrong? is it pressure? what should i be looking for ? what is causing the valve to leak or blow in such a short time? thanx gents Happy Travel www.thegippo.wordpress.com |
