Home > Maintenance & Modifications > Oil pump for filling gearbox etc
Cupboard
What do people use?
I've been using a cheapo one that fits on the top of an oil bottle but it's always been a pain to use and is now leaking oil all over the floor when you use it.
I've been looking at the ones that look like garden sprayers, do they work? What about the ones that are like giant syringes?
the garden sprayer type appeals to me because you can set it going whilst you drain the next part that needs servicing but if it's not up for gearbox oil then it's no good. I imagine the syringe type would be very difficult to get in to the gearbox and transfer box.
I'm open to general recommendations (this type is good) or specific "buy this one" type recommendations.
Post #737880 31st Oct 2018 9:20pm
geobloke
I am a massive fan of the Oil safe system. Been using it now for eight years or so.
So versatile and last forever.
http://www.oilsafesystem.com/oss-oil-safe
Post #737887 31st Oct 2018 9:41pm
sako243
Just pop down to B&Q, Wickes or whatever and buy the cheapest sprayer you can find. Will be a revelation.
Mind finally broke (locking lugs broke trying to undo it) but it has been left outside, thrown in the corner and was only a fiver to begin with. 4 years usage isn't bad... Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #737888 31st Oct 2018 9:42pm
barbel jim
Small funnel stuck in the end of 15mm copper pipe Mr. Green faultless Laughing I've put a slight bend in the end to sit better in the side of the gearbox.....
Post #737903 31st Oct 2018 10:14pm
zsd-puma
The cheap syringes are all crap, as you've discovered.
You need one of the laser tools ones like this, I have one it's fantastic.
https://www.lasertools.co.uk/product/5699
https://iforcemarketzone.com/products/lase...1873034293
Post #737959 1st Nov 2018 10:19am
MartinK
I have a B&Q one - had it a few years ow - works perfect
Just measure 2.2 litres of gear oil in, set it going and go for a cuppa! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #737962 1st Nov 2018 10:26am
dorsetsmith
^^^ Thumbs Up
Post #737967 1st Nov 2018 11:39am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
+1 for the B&Q sprayer bottle, works a treat for gearbox and transfer box πŸ‘
Post #737971 1st Nov 2018 12:19pm
Cupboard
lovely, thanks all.
Think I need to get myself a garden sprayer Rolling with laughter
Or maybe I could just use the portashower...
Post #738093 1st Nov 2018 9:46pm
I use this:
https://www.ebay.co.uk/itm/Sealey-TP6804-1...Swdd9aad1E
It is however only 1L, but it is small and not too big.
The choice is yours. Laughing TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #738096 1st Nov 2018 10:07pm
Cupboard
To bring this to a close, I sort of went down the sprayer bottle but with a bit of an upgrade.
I bought a Sealey VS70095
http://www.sealey.co.uk/PLPageBuilder.asp?...ctid=16206
Which is basically a garden sprayer designed to pump gearbox oil.
Used it this afternoon to change my front diff oil and it worked very well. A significant upgrade over the previous pump. It's so much cleaner, less effort and quicker.
Post #739691 10th Nov 2018 5:34pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Post #739712 10th Nov 2018 7:55pm
NickMc
Real men squeeze it out of the one litre bottle spouts, spilling it all over the floor, topping each bottle up so you can enough out, while dribbling it down the side, so you can get it right down in your arms and sleeves so your overalls and entire body get that nice leau’ Du EP90 stank! Get that right up your nostrils it’s good for the soul Whistle
Post #739724 10th Nov 2018 8:24pm
Nothing more British than the smell of old school Waxoyl and EP90 in the morning.
Along with a camp out, tent and some old fashioned bangers on a grille cooking.
Whilst you're there your subconsciously checking out the chassis and checking if there is any corrosion setting in.
Rolling with laughter TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #739725 10th Nov 2018 8:29pm
