![]() | Home > Maintenance & Modifications > Oil pump for filling gearbox etc |
What do people use?
I've been using a cheapo one that fits on the top of an oil bottle but it's always been a pain to use and is now leaking oil all over the floor when you use it. I've been looking at the ones that look like garden sprayers, do they work? What about the ones that are like giant syringes? the garden sprayer type appeals to me because you can set it going whilst you drain the next part that needs servicing but if it's not up for gearbox oil then it's no good. I imagine the syringe type would be very difficult to get in to the gearbox and transfer box. I'm open to general recommendations (this type is good) or specific "buy this one" type recommendations. |
I am a massive fan of the Oil safe system. Been using it now for eight years or so.
So versatile and last forever. http://www.oilsafesystem.com/oss-oil-safe |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1437 ![]() ![]() ![]() |
Small funnel stuck in the end of 15mm copper pipe
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The cheap syringes are all crap, as you've discovered.
You need one of the laser tools ones like this, I have one it's fantastic. https://www.lasertools.co.uk/product/5699 https://iforcemarketzone.com/products/lase...1873034293 |
I have a B&Q one - had it a few years ow - works perfect
![]() Click image to enlarge Just measure 2.2 litres of gear oil in, set it going and go for a cuppa! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
+1 for the B&Q sprayer bottle, works a treat for gearbox and transfer box 👍
lovely, thanks all.
Think I need to get myself a garden sprayer ![]() Or maybe I could just use the portashower... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
I use this:
https://www.ebay.co.uk/itm/Sealey-TP6804-1...Swdd9aad1E It is however only 1L, but it is small and not too big. The choice is yours. ![]() ⛽️🛢️⚙️🧰💪 |
To bring this to a close, I sort of went down the sprayer bottle but with a bit of an upgrade.
I bought a Sealey VS70095 http://www.sealey.co.uk/PLPageBuilder.asp?...ctid=16206 Which is basically a garden sprayer designed to pump gearbox oil. Used it this afternoon to change my front diff oil and it worked very well. A significant upgrade over the previous pump. It's so much cleaner, less effort and quicker. |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 152 ![]() ![]() |
https://www.defender2.net/forum/topic63079.html Cheers
Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Real men squeeze it out of the one litre bottle spouts, spilling it all over the floor, topping each bottle up so you can enough out, while dribbling it down the side, so you can get it right down in your arms and sleeves so your overalls and entire body get that nice leau’ Du EP90 stank! Get that right up your nostrils it’s good for the soul
Nothing more British than the smell of old school Waxoyl and EP90 in the morning.
Along with a camp out, tent and some old fashioned bangers on a grille cooking. Whilst you're there your subconsciously checking out the chassis and checking if there is any corrosion setting in. ![]() ⛽️🛢️⚙️🧰💪 |
