![]() | Home > My Defender > Daisy the Doublecab |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Personally I’d ask a shop to fix the holes or even change the wing because of the holes.
That's the engine air intake. It won't make a difference to high cabin temperatures, which are largely a result of the gearbox and exhaust under the floor. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
You sir are assuming that’s where my intake is, it it were factory spec then maybe so. But it isn’t.
Air intake is via a 4inch pipe to the wing top. So the wing side just has a hole in it. Now has more air being pushed into it when driving along. We shall see. A new wing is on my shopping list and I’ll get to it eventually. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
It seemed like a reasonable assumption
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
So far so good. Air inlet temps have stabilised. Since I put the new intake pipe in the temperatures were rising. So if nothing else it’s solved this problem upto now.
Will see how the footwell temperature goes on my journey upto the Peterborough show next week. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
No more wheel on the roof. Reduce the C of G a bit! Safari equip galvanised wheel carrier fitted yesterday.
![]() Click image to enlarge ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Looking good! Just out of interest when you swing it away does it lock open, so to speak, or just swing about?
I was admiring Daisy at the LRO ![]() ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanks James 😎
It doesn’t lock open, it has a steel cable that stops it from going too far. I’m working on an idea of a gas strut to hold it open as it’s only been on 12hours, and bashed me on the back already. Obviously with the drop down open it can’t close. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Thank you.
The powers for the switch... Back illumination is just piggy backed from an unused connector behind the dash as it’s a double cab. Actual power is fed via a relay to the lights. The switch is just a trigger to activate the relay. Fed via a blue sea fuse box I have situated next to the battery. ![]() Instagram - @r22oyp Roy |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Ok thanks. I have a winch isolator solenoid to wire up using a factory switch, trying to fathom how to do it! Will research further. I have a double cab also - what unused connectors are there? Wondering whether anything is available for the switched live
edit: researched and found the answer to my own question... heated rear screen, rear washer, rear wiper. Think I will use one of these. |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
![]() Click image to enlarge http://www.defender2.net/forum/topic552.ht...p;start=15 http://www.defender2.net/forum/topic56375....ght+switch Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
yep, pretty much wired up the same as above. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Just a couple photos before the pig shed goes back on the back 😩 **well there would have been but they won’t upload 🤔
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 ![]() ![]() |
Great pic Roy
